- Sep 25, 2023
- 781
- 975
- Swift Sundance 590RS
I wasn't clear when I said only work where there is charge to the leisure battery, but I did say if the leisure battery is not on charge it is not ideal as it will pull the LB down.Most of that is inaccurate. No power is needed to the hab battery as the unit operates on voltage differential NOT any particular voltage. The transfer rate is 1.1A trickle but I'm not sure of the voltage differential. This link explains most....https://www.vanbitz.com/the-van-bitz-battery-master/
I was trying to say that the ideal set up is provide charge to the leisure battery to keep the setup topped up.
