- Sep 25, 2023
- 781
- 975
- Swift Sundance 590RS
We dont have solar yet but would like to keep the batteries topped up whilst in storage. Been reading a lot about Windscreen solar chargers at 20 to 30w connected to the vehicle battery but would also like to top up the leisure as well if possible.
I'm no expert in vehicle electrics although I have installed bits and pieces over the years in cars. The MH is a 2002 Ducato base with a 94ah engine battery and a 150ah leisure battery.
Behind the drivers seat there was some poorly maintained wiring that comes from under the drivers seat in to the seating area where the water tank is located. There is also a 20AMP inline fuse located here. I've wrapped the cables in loom tape and housed the connection in a choc block box for now with the 20amp fuse alongside (not in the box) and easily accessible from the drivers door.
In the wardrobe behind the EHU socket is the charger and a relay. The relay is mount directly to the back of the wardrobe wall. Not sure if this is the split charge relay.
Any thoughts about how I could install a suitable panel. Lots of cheap rubbish out there. Any recommendations on a suitable setup for this. We are new to Motor Homing and I don't want to be throwing lots of money at solar just yet as we are likely going to be on EHU when we can.
