No lights or pump in motorhome (2 Viewers)
JMS25
Elnagh Marlin 65
No lights or pump in motorhome, control panel switches for same won’t light up, everything else on panel works, sockets working, batteries ok, EHU seems good,
Checked fuses. batteries with multi meter. what am I missing?
Thanks in advance
Feb 19, 2018
5,643
90,918
EAST ANGLIA
Murvi Morello
Since 1975
I know little about electrics BUT, I would check out the trips or the main fuses but you say you have checked those? 🤔
9,878
51,902
Hurstpierpoint. Mid Sussex.
Compass Navigator
Presumably you mean when on EHU, but even on EHU those items require 12v.
Is the fridge working? It's control circuit needs 12v even when on EHU.
Is the m/home new to you? Have those items previously worked?
sockets working
12v sockets or 230v sockets?
  • Informative
Reactions: f6c
J
JMS25
Elnagh Marlin 65
Yes all items have worked fine previously, 230v sockets.
9,878
51,902
Compass Navigator
I don't know your specific system but you'll need to follow the 12v from the leisure battery with a meter until you can no longer get a 12v reading on the meter. Start at the battery. You said you've 'checked the fuses' but did that include the large 30 or 50 amp main 12v supply fuse which is usually adjacent to the leisure battery?
2,182
1,250
Bracklesham Bay, West Sussex
If you remove the cover off the 12v distribution box there are multi plugs that may be worth checking in case one is loose , you can also check there if power from both the leisure and starter batteries is reaching the distribution box.
