No but I have found a fuse in the boiler, however it tested okay. We're travelling at the moment but when we stop I'll give alde a ring as someone suggested earlier. Thanks.
Kettle, microwave, fan heater, charging sockets, all fineWhat do you mean by "everything else in the van works fine". Most of the van electrics are 12V and work from the battery. Are you sure you are getting 240V through to the van? Is the fridge on 240V at present? Have you tried plugging a 240v appliance in to see if it is working?
Do you mean the 3.15 fuse in a little green plastic case? If so we checked that out.We had an issue with ours and was told to take the fuse out that is on the boiler itself (under the black plastic cover on the top in ours) then simply replace it and all will be well.
I rather dubiously tried this and it has worked perfectly ever since (we have a 2017 Bailey Autograph).
If it will help and I get time I will get a photo of the fuse I mean later)
