petrol tin glyn
i had the same checked everything all ok but no 240v any way started up the onboard genny run that every thing worked,shut it of all ok 240v back to normal strange or what ??
Dirty relay contacts mains / genny changeover?i had the same checked everything all ok but no 240v any way started up the onboard genny run that every thing worked,shut it of all ok 240v back to normal strange or what ??
Completely over engineered for a motorhome.....just like the electrobloc control panel.I spoke to a friend of mine today who used to have a a '58 reg Swift. He said exactly the same thing happened to him a few years ago. He spent a couple of hundred getting the fault sorted before some one asked if he had checked the battery in the control panel above the habitation door. He found it was corroded and starting to swell, he changed it and it worked!
I thought it was worth a try and took myself off to Maplins at 9:00am this morning. By 10:00am the battery was changed and my 240 volt was working in the van! Now that's what I call a result!
How can a £3.99 lithium battery cause the 240 volt supply to stop working?
Without drawings I don't know but I bet I could find the battery cheaper
Sorry I had opened this and not responded due to a distraction. Glad to hear you sorted it.
I am so glad I don't have a fancy motorhome whereby a cheap battery can stop 240V from working
Yer car doesnt have this much complication.
No 240 volt supply?I'd be willing to bet that the fuse in your adapter has blown. There is a considerable load on the fuse when the MH is being checked over. I'm certain that the fault is not on your MH.
Robert.
Yes we're all dumbstruckAh I hadn't seen page 2! Now I am surprised lol....
Well I don't think I have a fancy MH, but it does seem ludicrous that a cheap battery can stop a 240 volt supply from working!
Robert.
Oh it does - it really doesYer car doesnt have this much complication.
Unfortunately the 3 pin plug on the adaptor lead will be rated at 13amps.......putting in a larger fuse (if you can find one that fits the plug) is foolhardy.Yes, the fuse in the adapter should be a 13amp one but the MH can draw more than the fuse can handle.
Change the fuse in the adapter & all will be well again.
Robert.
Not for a simple function like turning on a basic switch.Oh it does - it really does
Not for a simple function like turning on a basic switch..
