Nextbase Dashcam 522GW
The reason that it is recommended to reformat the SD card regularly is due to the fact that every time the camera is started or stopped it creates a fragmented file. In itself not an issue but if the camera is used daily, and restarts a few times a day (set up to switch on/off with the ignition) then you end up with a number of fragmented files which can cause performance issues with SD cards. Recommendation from most manufacturers of Dashcams, and SD cards used in dashcams, is to reformat on a regular basis to ensure top performance. How often is regular will depend on how often the camera is stopped.
Correct :) As things are I will think about doing a format around June time............ June 2027 !!!
I have a Transcend dashcam and have never needed to reformat the sd card apart from when I first installed it.
