- Dec 2, 2024
- 9
- 14
- Adria Vision i677sp
Hi again - thanks for the info. It's opened my eyes a bit. I hadn't realised you could that much out of a battery.Aa an example, we have a 304Ah Fogstar lithium and a 3000W Renogy inverter. We rarely use gas and can stay 'off grid' at the same location for around four days with very little solar BUT extensive use of 240v for cooking etc
Other Funsters have bigger and better 'stuff', so do some research before committing
We'll have 240Ah with the new pair of batteries and a 300W inverter as a starter pack, which we plan to experiment with. Nothing like your setup, but hopefully it will give us a taste of off-grid life - which we're yet to try!
As an example, what we have in mind for one of our main trips next year is taking our time travelling down from the Chunnel to Portugal and then on to Southern Spain and back up though France, making use of the Aires, off-grid spots et al along the way for overnight stops - two nights max. So the off-grid would mainly consist of such stops, with not too arduous drives of 4 hours or so in between. Being retired, we'll be in no great hurry . There'd also be some stops at several campsites with EHU along the way, at points where we want to have a day or two looking around. In central Portugal and Southern Spain we'll be stopping for two or three weeks at predetermined campsites.
Use of the electrics off-grid would therefore be mainly overnight stops where we'd be using lighting, Satellite TV, Mifi, laptop, phones, water pump and alarm system (all 12v), and possibly using the 300w inverter to boil the kettle a few times for tea and coffee and to power our Alexa in the mornings - although we could use gas for the kettle and mobile phones for radio if needed. Obviously, most of this use would be after sunset, with just a few hours of daylight in both the afternoon and morning for the solar panels.
Obviously, I haven't done the maths yet and we have to do some experimenting off-grid to see how the new battery setup measures-up before we go; but given your experience, do you think it would be feasible on a 240Ah battery set with nominal solar input?
I'm yet to determine what output we're getting from the solar panels as I have no spec on them and have only just taken delivery of my Kaiweets KC604 clamp meter. I'm not going to be able to get any meaningful readings now until after the winter. However, last summer we mostly saw 1 - 3 amps on the control panel, albeit there wasn't a lot of sunshine and we later discovered that the leisure battery was way past its useful life and needed changing - with 'Defect' displayed on the control panel. I understand the spent battery would have contributed to the low readings.
Anyway, we really appreciate your help. Thanks a lot .
Roger & Anne
