Newbie couple with F Ducato Granduca Pegaso 63
Bodmin
Fiat Ducato Granduca
I'm a newbie
Thanks for including me. We bought Duchess, our 1998 2.5 MH in July this yr. Haven't been out in her yet ☹️. Discovered a lot of the wiring was burnt out, cut off or held together with sticky back plastic! Luckily my husband is an electrical/ mechanical engineer & almost finished completely rewiring her. Hoping 12v will then work, although the leisure battery is 80AH, which I gather is not too good. Planning on a solar panel at some stage. Will probably need lots of advice as we move along.
Aberdeenshire
low profile
Welcome 👋 80 ah is very small unless you are going to use hook up each trip. If you can then choose lithium, if not the biggest ah battery you can fit.
