Minxy
- Aug 22, 2007
- 33,977
- 71,516
- Carthago Compactline
- Since 1996, had Elddis/Swift/Rapido/Rimor/Chausson MHs. Autocruise/Globecar PVCs/Compactline i-138
Sounds interesting - any pictures? ... not of it 'in use' you understand!It looks pretty much like a normal wc, with a standard soft close seat, you sit to do everything !!! the urine does into a urine diverter, from 'Free Range Designs' into a container and poo falls into a square container lined with a large compostable food liner (or two) that has a drying medium, wood pellets, coconut hair, wood shavings anything that absorbs moisture, then cover with a bit more trying medium, a hole is made in the back of the WC box and flexible tube (old vacuum cleaner hose) is attached with a small fan that constantly draws air into the WC box and exhausts it through the hose and out through the bottom of the van, this dries the poo (poo is around 80% water). Its a ply box, vertical exterior is clad with thin copper sheet (from scrap yard) and the rest of the ply I've covered with polyurethane white Gell coat so it can easily be cleaned.
