- Sep 25, 2023
- 684
- 851
- Swift Sundance 590RS
Recently purchased a 100w folding panel with a simple MPPT controller. The controller just shows solar input, charging and charged through 3 LEDs. The panel is currently in the windscreen and luckily facing south if I drive in to my storage spot rather than reverse in. In this weather as expected the output varies considerably and not the steady output you would get from a regularly mains intelligent charger. I have split relay charging on the road and when off grid a few days at a time such as festivals, the idea will be to charge the leisure battery and use a battery master to top up the vehicle battery but I need to get my head around the wiring first, it’s a 21 year old MH. Vehicle battery is Varta 95ah and leisure is 105ah. Both are standard wet lead acid batteries.
I have attached a BM2 to both batteries, the leisure battery is fine and hasn’t dropped at all, but as you would expect the vehicle battery does. Over the dull days VB will drop to around 65%. It’s not dropped below that before we take the MH out. To my surprise a few days ago the BM2 was reporting fully charged at 100%, happy days. When looking at the input via the BM2 app, you can see the voltage variation over time, will this harm the battery.
Below is screenshot from Vehicle Battery BM2 2 days ago.
Below is the BM2 recorded voltages over 15 days.
