kcy
motorhomes for the disabled
do blue badge holders get a discount on new motorhomes?
Not specifically because someone is a blue badge holder, but if you are able to sign the requisite form that allows you to be supplied with goods designed for disabled people at zero rate Vat, then you can have your motorhome zero rated provided it has been 'significantly & permanently' adapted to suit the requirements of a person who uses either a stretcher or a wheelchair.do blue badge holders get a discount on new motorhomes?
New & second hand vehicles are eligible, but while Vat is applied to the full price of a new vehicle (so the saving is significant), Vat is only levied on the dealer's margin when buying secondhand, so the saving will be in hundreds, not thousands (unless it's a very expensive s/h vehicle).
'Significant & permanent' is not defined, but is usually interpreted to mean that the modification is welded or bolted in place. So a wheelchair hoist would count, but portable ramps are a grey area. Some dealers will zero rate if the ramps have a safety slot (into which the ramps clip) bolted to the floor. Others won't consider ramps at all.
You can use your Mobility Allowance pretty much any way you like & there's certainly no reason why you shouldn't use it to part fund a motorhome.I believe that Mobility allowance can be used towards the purchase instead of a car.
Unfortunately this post originated nearly 5 years ago and the OP didn't stay around. There have been sporadic extra comments since but that's all.I am the only driver as my husband is disabled. We would like as small as possible. A wide entrance door with a good grab handle and possibly an opening door at the back for when he will require a wheelchair. Kindest regards.
Have a look at this one - WildAx CallistoI am the only driver as my husband is disabled. We would like as small as possible. A wide entrance door with a good grab handle and possibly an opening door at the back for when he will require a wheelchair. Kindest regards.
