Brilliant load of info here.. Thank you everyone.
What I have got from this so far:
My solar controller has pin 1 and 2 connected to panels. Has pin 3 and 4 running off the battery (is the presumption - but makes perfect sense). Pin 5 and 6 are unconnected.
My PMS3 rocker switch is supposed to run off Van/Leisure or Car. The fridge and lights only work when switched to Van.. so that makes sense. When I switch to Car... I do not seem to get anything so that is wrong from what was explained. Unless I am being impatient.
There is a nagares 12v split relay installed and a 100A fuse under the drivers seat. I wonder if that 66AH is actually NOT a leisure battery and an auxilary as mentioned... hmmmm.
Sounds like I need to check if the b2b is on the alternator. I suspect not as is just the split relay.
Fridge does not run on gas AFAIK. Only seen demoed on electric.
No sockets work unless EHU I am told. Will plug in to prove/disprove this.
No heating unless plugged in... have seen this.
Happy to kit out with 12v appliances only. Bought a mini screen that is 12v for example.. arriving at the weekend. And also bought long cables and DC barrel inputs so can make up some long wires at the moment.
Diesel heaters. Sounds like I need to carry fuel or in a Tranny is the main tank enough if I keep topped up?
Happy to buy new battery and upgrade solar as it was done about 8 years ago from what the previous owner was told.. if all accurate. It is a big panel with big chunky silver frame etc...
So my conclusion and a few questions - thanks for being so helpful so far.. really feel green on this:
a) Need new battery. I am checking out the sites suggested. But with being so green I really do not know what I am looking for as I have seen lots of comments on Google. Can I get a £120 ish 110AH leisure battery and that is ok?
i.e. https://www.tayna.co.uk/leisure-batteries/motorhome/
or
a higher AH deep cycle (understanding I want deep cycle I think for wild)
<Broken link removed>
b) Can my existing 100A split relay and 100A fuse take this? Do they correlate or are we talking just load here on the van as opposed to charging?
c) Sounds like my 66AH battery is TOTALLY NOT a leisure battery as the dimensions alone are car battery size and NON of the leisure batteries I have seen are anywhere near these tiny 27cm L, 17cm W and 12cm H. Looks like I need to rewire to under the sofa and secure to get a real leisure battery in!!! That is fine. I am handy.
d) Why does my van not run on Car mode on the PMS. Wiring issue maybe?
e) Heating.... hmmmm..... I am handy but assuming I need someone to get this sorted for tapping into diesel tank and installing a diesel heater. Please advise.
As I say I am very handy. However, this is a new area so I do need direction.. but with direction I can do most things where I can do it and understand I might need someone to get involved here.
f) For wiring... please can someone points me to diagrams. I have original 2 page wiring diagram for PMS... so can investigate how it is wired up by pulling up stuff.. Any initial comments though? Thanks for 6x way fuse box. Again.. point me to where to install within the system (what you would expect).
g) Diesel heater.... Again need some direction this.. I am on the Wirral. Anyone near that does this? I want to have a great first experience and happy to spend some money to get this right so we know over next couple of years do we want to really do this and even change up van. (We suspect we do already ).
You have all been really helpful as I am truly green. But VERY VERY willing to learn.
Please let me know on the battery as I want to get one on order today.. and looks like I might need to rewire.
MANY THANKS in advance.
R
or
R
