Gazza333
Strange I can get acsi. Aires cci bored atlas working but not Archie's. it just doesn't show even though I've done the same ......time to scratch head
I can only see 2 files for Archies the .bmp and .kml files. Is that correct?
Lunar man do u have yours running of the sd card?
Anybody changed the vehicle icon to a motorhome yet or downloaded some new voices?
Yes I am running mine from the SD Card
So I'm not with mine this weeken so can't play but if I can move everything to the sd card and run it from the then I assume I can have masses of poi files and all the maps as well as its 8 gb.
Is it easy to do Lunarman? Is it easy to do a instruction post on how to do it?
Many thanks for all your help
I think I've worked it out .....
Using Windows Explorer or Mac Finder, copy all files to you computer as a backup first.
Then all the files that are on the built in memory copy across to the SD card (this should just be the IGO9 folder and all contents).
Next copy the nng file from the SD card to the internal memory.
Finally delete the IGO9 folder from the internal memory.
You'll then need to change the Navi Path to the SD card - you'll be asked to do this the first time you try to navigate.
Sounds good and does it then all work steelysteph
sorry to resurrect an old thread but I'm stuck,To get the points to show on the map as you travel you need to set them in the satnav
From the "Navigation Menu" select "More" then "Settings" in the settings menu find "Map Settings" then find "Place Markers" select each category of marker you want to appear on the screen. :thumb:
Easy innit
John
