N+B New iSMOVE - 3.5t this is the one.
A few problems with that:
I somehow don't think that my Suzuki GSX-R 1000R (which develops way more bhp than the motorhome - over 200) will go on the back of it and still have a legal rear axle loading (although the moho might pull some descent wheelies 🙂)
My classic race bikes are far to precious to be left dangling on the back of a moho
But the biggest problem for me, is there is absolutely no way I'm ever gonna have a girly pop pop scoo.... scoo...... scoo - I can't say that word - I'd sooner walk🙂
Go on, say it, scoo ta, scoo ta, there it’s easy. My Sym HDi 200 goes on the back of mine a treat, no slouch either, 70 mph easy. Unicycle would fit in the half garage too.
Phil
Some ideas look interesting, like re arranging the seating area for travel and at a stop, not sure about the kitchen/wc access. You can't really jump to firm conclusions of what it's like from a promotional video 🧐. So looking forward to seeing it in the flesh and checking out the quality.
Hopefully, the good ideas will evolve and last so that in 5 years time when we look to change they will be mainstream👍 (and second hand).
Has anyone seen the price yet?
They are trying hard to fit a fully functional 'quart' motorhome into a 3500kg 'pint pot'
I think it cannot be done and keep the N&B quality of design and build.
Geoff
And thats it in a nutshell; we've seen how the C tourer and the Exsis worked out, it will be a shame if N&B go the same way.
£71,000 + VAT according to website.
Smove
The sporty all-rounder
EN
Price list Model year 2021
Content
03 Standard Equipment Smove 06 Technical Data
08 Equipment Packs
10 Optional Features
18 Important Information
Smove
Models 2021
Standard Equipment Smove Chassis
• Fiat Ducato 35L
• Airbag for driver and passenger seat
• Turbo diesel engine with electronically controlled Common
Rail Direct Injection
• Emission class Euro 6 d temp with exhaust gas recirculation
• Manual 6-speed transmission
• Electronically controlled anti-lock braking system (ABS)
• ESC
• Traction control, hill holder, traction+ and hill descent
control
• Disc brakes on front and rear axle
• Electronic brake pad wear indicator
• Electronic brake force distribution (EBFD)
• Alternator 14 V/150 A
• Battery 12 V / 95 Ah
• Tyre sealant with compressor (Fix + Go)
• Tyres with traction profile (mud and snow identification)
and 225 / 75 R 16 steel wheels
• Independent suspension on front and rear axle
• AL-KO-lightweight low frame chassis with maximum
frame lowering (144 mm)
• Hot-dip galvanised frame elements and wide chassis
• Bracing of the chassis by means of a 42 mm thick sandwich
floor panel screwed and glued to the AL-KO low frame
• Reinforced 3-shell B-pillar for a higher torsional stiffness
between the driver’s cabin and the bodyshell • Fuel tank 90l + 19l Ad Blue tank
6.9 Q
7.4 E
Smove Models 2021 3
Driver’s Cab
• Panorama front hood out of resistant glass fibre, double shelled and insulated
• Tinted, large fixed skylight with darkening plissé
• Driver and passenger seat, rotatable by 180° and height
adjustable
Bodyshell
• Exterior panels including garage hatch made of torsion- resistant 2-sided-aluminium sandwich construction (30 mm) with styrofoam insulation
• Roof in sandwich construction (30 mm), torsion-resistant with styrofoam insulation, inside aluminium, outside corrosion-free GRP High Strength X-treme including
gel coat sealing
• Ceiling-to-wall connections without cold bridges, by means of highly compressed PU hard profiles
• Box structure without wood
• Lighting protection because of Faraday cage
• Roof side sillboard in automotive design and roof rain
water channel to reduce side panel soiling
• Aerodynamic roof shape and B-pillar covering for lower
drag and driving noise
• Outer plate smooth, stove-enamelled white
• Panorama front hood, rear bumper, wheel case cover
and side skirts as well as rear panel of highly stable and corrosion-free glass fibre composite material
Living and Sleeping
• Textile covering on the interior of the side panels and roof
• Padded decorative elements on the inside of the roof
and of the B-pillars
• Wear-resistant floor covering in stone tiles look
• High quality wear-resistant upholstery in 27 different
combinations (plus leather for an additional charge)
• Seat cushions with high comfort thanks to a 3-layer
foam concept
• Lounge table with multi-directional displacement
mechanism
• Practical drawer in the entrance area with electrical
locking
• Solid handle covered with leather for easy entry
• Continuous overhead cupboards in living room and rear
bedroom with push-to-open system (gas pressure buffers) for a maximum comfort in use
• Cab’s doors with electrical side windows
• Height-adjustable steering wheel
• LED lighting in the driver’s cab
• Dashboard with cup holder and chrome rings
• Heated and insulated double floor of ca. 270 mm height • Water and waste water tank frost-proof integrated in the
• Solid entrance door with electric closing aid, double
locking and window
• Exterior, electrically operated entrance step, with auto-
matic closing system, while starting to drive
• Spacious rear garage with lighting, heatable
• Rear garage door, passenger side (right), with low loading
height
• Rear garage floor coated with highly wear-resistant
dimpled membrane
• Insulated bodyshell windows, double-glazed plastic
window in outer aluminium frame with PU insulation, with
pleated darkening blind and insect protection
• Garage walls covered with needle felt
• Tie system in the garage including 4 adjustable eyelets
in each rail
• Indirect ambiance lighting with LED-technology for lounge area (dimmable) and rear bed
• Rear bed with lath frame and comfortable cold foam mattress
• Window on drivers side in bedroom, additional window on passenger side in model 7.4 E
• Power LED reading spots in the rear bedroom as well as in the living room
• Bed access with night lighting
• Step to access the rear single beds with storage space • Flexible reading lights at the rear bedroom
• Automatic floor lighting in the living room podium when
opening the body door
4 Content
Kitchen
• Innovative kitchen concept turning a sideboard into a loft kitchen
• Kitchen working surface out of safety glass
• High quality two-flame stainless steel gas cooker with
electric ignition, built-in in the working surface
• Single-lever mixer tap
Bathroom and Toilet
• Intelligent bathroom concept with swivelling washbasin and sliding toilet with electrical mechanism
• High-quality bathroom door with stainless steel door handle set
• Entire bath cab made of wear-resistant GRP
Heating and Water
• Centralised, heatable water disposal compartment on driver side, discharge cocks for waste water / fresh water tank with large diameter (1 1 / 4") for comfortable discharge
• Fresh and waste water tank in the heatable double floor, frost-proof
• Screwable water connection for the pump and the filter
• Air heating from Truma (Combi 6)
Electronics
• Central electronic system in the garage, easy to access
• AGM battery 95 Ah
• Charging set 16 A with electronic control
• Battery control system with protection against overload
and complete discharge
• Power-down of the electrics in case of undervoltage or
overheat
• 230 V CEE connection on driver’s side, protected and
accessible behind a hatch
• Automatic fault current circuit breaker
• Electrical central locking of the lower kitchen cabinets • Kitchen drawers with pull-in mechanism
• Refrigerator 140 l, with built-in freezer and large cool
compartment for 1,5 l bottles, AES automatic • Waste bin in the lower kitchen cabinet
• Foldable Single-lever mixer tap
• Spacious shower tray with seating stool
• Cassette toilet with trolley system
• Bathroom with towel rack and hook
• Roof-light with insect screen and pleated darkening blind
• Openings for cleaning on top for fresh and waste water tanks, accessible from the lounge area
• Integrated warm-water heater for the supply of all consuming points
• Centralized boosted water supply over silent pump including filter system
• Space for 2 × 11 kg gas bottles
• Mono control crash sensor for gas pressure regulator
• Centralised control panel with digital display
• 4×230Vsocketsand2×USBsocketsinthe
living room (depends on model)
• Lights (roof spots, spots under ceiling cupboards and
reading spots) in LED-Technology
• Indirect ambiance lighting (dimmable) in living area
• LED-lights in garage and water supply compartment
Content 5
Technical Data
Base vehicle
Chassis/Frame
Engine
Output in kW/HP
Maximum torque in Nm Type
Engine displacement in cm3
Chassis / Tyres
Wheel base in mm
Number of axles
Dimensions and weights (without accessories)
Overall length in mm
Overall width in mm
Overall height in mm
Technically permissible laden mass in kg
Mass in running order in kg approx.1)/4)
Maximum payload in kg2)
Technically permissible towing weightbraked in kg3)/5)/6)
Seats
Seats fitted with 3-point safety belt4)
Couch behind driver (length × width) in mm
Couch behind passenger (length × width) in mm
Beds
Rear bed(s) (length × width) in mm
Filling quantities
Fuel tank in l
AdBlue tank in l
Water tank content in l in driving/camping mode
Waste water tank in l
Gas supply in kg
Dimensions of the garage
Maximum garage height in mm
Maximum available surface (length × width) in mm
Smove 6.9 Q
Fiat Ducato, Euro 6d-Temp
AL-KO low frame AMC 35L (opt.: AMC45H)
Heavy Duty Homologation
96/130 (opt.: 118/160)
350 (opt.: 400/450)
4-cylinder TD with VGT turbocharger
2,287
4,100
6,930
2,245
2,770
3,500 (opt.: 3,650/4,500)
2,930
570 (opt.: 720/1,570)
1,850 – 2,000
2 (3,4)
895 × 557
1,215 × 577
2,000 × 1,500
90
19
20/140 (opt.: 200)
130
2 × 11
1,140
2,060 × 1,000/1,070
Light Duty Homologation*7
103/140 (opt.: 118/160, 132/180)
350 (opt.: 380)
Price in EUR, ex works, VAT not included
71,000
6 Technical Data
Base vehicle
Chassis/Frame
Engine
Output in kW/HP
Chassis / Tyres
Wheel base in mm
Number of axles
Overall width in mm
Seats
Beds
Filling quantities
Fuel tank in l
AdBlue tank in l
Gas supply in kg
Smove 7.4 E
350 (opt.: 400/450)
2,287
4,250
7,430
2,245
2,770
3,020
480 (opt.: 630/1,480)
1,850 – 2,000
2 (3, 4)
895 × 557
1,215 × 577
2,000 × 765/765
90
19
20/140 (opt.: 200)
130
2 × 11
1,140
2,060 × 1,000/1,070
1), 2), 3), 4), 5), 6), 7) on page 18
350 (opt.: 380)
74,353
Technical Data 7
Equipment Packs CP Comfort Pack for all models
Code Description
86180 CP–Comfort Pack (special price)
86179 Aguti comfort seats for driver and passenger, orientable and adjustable in height, in textile (instead of the original Fiat seats)
Price EUR
VAT excl.
12
857
748 580 412 269
2,866
–1,193
Price EUR
VAT excl.
25.5
1,592
244 176 269 395 138 91
2,905
–981
Price EUR
VAT excl.
5,286
2,344 1,353
8,983
–3,403
Weight
in kg
86029 Darkening pleats for front and side windows in the driver’s cab 86089 Comfort mattress incl. Froli bed system
86177 Body windows with one-hand operation
86178 Fly screen net for body door
Total individual prices Minus price advantage
CHP Chassis Pack for all models
PACKAGE PRICE
1,673
Code 86181
Description
CHP – Chassis Pack (special price)
Weight
in kg
86135 Automatic air conditioning with pollen filter in driver’s cabin 86136 Cruise control
86176 Fog lights
86171
LED daytime running lights instead of standard lights 86003 Exterior mirrors electrically adjustable and DAB + antenna 86139 Dashboard decor with aluminium inlays
86187 Loose carpet in the driver's cab
LEP Lithium Energy Pack for all models Code Description
80032 LEP–Lithium Energy Pack
Weight
PACKAGE PRICE
1,924
in kg
31
86220 2 x 100AH Lithium batteries (instead of AGM battery monitor and batterymanagement panel
86035 70Acombichargerwith1,600wattinverter 86224 160W solar system incl. MPPT regulator
batteries)
incl.
charging
booster,
PACKAGE PRICE
5,580
8 Equipment Packs
MMP Multimedia Pack for all models Code Description
86184 MMP – Multimedia Pack (special price)
86038 “Sound-system”radiopre-cablingincluding4loudspeakersandsubwoofer
86040 Navigation system with 7" touch screen incl. tuner with DAB+, DVD slot, bluetooth and reversing camera behind lily logo (only in combination with radio precabling code 86037 or 86038)
86044 LEDTV22"inmediatower,incl.integratedDVB-S2/DVB-T2receiver,DVDslot and resonance loudspeaker
86041 Oyster Cytrac Vision satellite (without receiver) Total individual prices
MP1 Multimedia Pack without SAT system for all models Code Description
86396 MP1–Multimedia Pack without SAT system
86038 Radio pre-installation “Sound System” with 4 loud speakers and subwoofer
86040 Navigator unit with 7" touch screen incl. radio with DAB+, DVD slot, Blue Tooth and back-up camera behind lily flower
86044 LED TV 22" in media tower, incl. integrated DVB-S2/DVB-T2 receiver, DVD slot and resonance loudspeaker
Price EUR
VAT excl.
48
958
1,597
748
2,933
6,236
–1,454
Price EUR
VAT excl.
24
958
1,597 748
3,303
–706
Weight
in kg
PACKAGE PRICE
4,782
Weight
in kg
PACKAGE PRICE
2,597
Equipment Packs 9
Optional Features
Chassis
Code Description
1408 Fiat Ducato, Light Duty homologation*7
1409 Fiat Ducato, Heavy Duty homologation
86125 Fiat Ducato Maxi AMC45H, 4,5 t total weight 86225 Automatic gear box ZF AT9
86130 2,3 l engine (160 HP) Light Duty homologation*7 (only in combination with code 1408)
86400 2,3 l engine (160 HP) Heavy Duty homologation (only in combination with code 1409)
Weight
in kg
In package
Price EUR
VAT excl.
2,681 3,689 244
181
181 1,224 138 395 272 5,706 1,592 269 1,168 1,168 2,261 231 5,790 176 378 285
0 40 30 0
0 10 0,5
0 35 0.5 1 10 70 18 0 0 0 12 0 30 2 25 0
0 1,305 2,815 1,782
2,3 l engine (180 HP) Light Duty homologation*7 (only in combination with code 1408)
86138 Multifunctional steering wheel
86155 Weight upgrade to 3,65 t for Fiat Ducato AMC 35L
86127 Reduction of total weight to 3,5 t for Fiat Ducato Maxi AMC 45H 86008 Towing attachment (detachable) incl. rear traverse extension
86003 Exterior mirrors, electrically adjustable, incl. radio antenna (DAB+) 86163 Rear axle supports (2 crank supports)
86199 Hydraulic steady legs (AL-KO HY4) with automatic leveling function 86135 Automatic air conditioning with pollen filter in driver’s cabin
86171
86013 16" alloy wheels for Fiat Ducato AMC 35L
86014 16" alloy wheels for Fiat Ducato Maxi AMC 45H
86017 18" alloy wheels for Fiat Ducato Maxi AMC 45H*7
86137 Steering wheel and shift knob in leather
86175 Goldschmitt rear air suspension incl. lifting and lowering device
86176 Front fog lamp
86018 16" spare wheel instead of Tire-Fit
86156 Automatic Start/Stop system (standard for 160HP and 180HP engine)
7) on page 18
86131
LED day running lights instead of standard ones
CHP CHP
CHP CHP
CHP
86013/86014 Alloy wheels 86171 LED day running lights
Optional Features 11
Code
Description
Weight
in kg
In package
CHP CHP
In package
Price EUR
VAT excl.
91
244
832
Price EUR
VAT excl.
86187 Loose carpets for the driver’s cab 86136 Cruise control
3 1
86157
AEBS (Advanced Emergency Braking System) including lane keeping assistant, high beam assistant, traffic sign recognition, light and rain sensors
CP Comfort Pack, CHP Chassis Pack, LEP Lithium Energy Pack, MP1 Multimedia Pack without SAT system, MMP Multimedia Pack
Cabin and Living Room
Code Description Weight
in kg
ClouLine-Design (black radiator cowling frame with radiator cowling and front bumper in own design and chrome profile, side spoilers at driver’s cab and between cab and body, in the same colour as the model, in robust glass fiber, chrome applications at the back)
11
86012
86204 Vehicle full painting
(window frames and plugs in anthracite or black, roof in white)
86217 Exterior decoration “Maxi black pearl”
86215 Exterior decoration “Carbon optic”
86205 Accent decoration “Champagner Matt”
(Design sticker on front and rear panel and skirts)
86206 Accent decoration “Lava Orange”
86207 Accent decoration “Miami Blue”
86208 Accent decoration “Carbon Optik”
86177 Body windows with one-hand operation 86079 Extendible table in living room
86025 Window at rear bed (standard in models 7.4) 86178 Fly screen door for body door
86021 Electric panorama sunroof over living room (to be activated from the driver’s cab) 86089 Comfort mattress incl. Froli bed system
86186
86031 3.75 m awning incl. dimmable LED lights (only for models 7.4)
86032 3.25 m awning incl. dimmable LED lights (only for models 6.9)
86023 Panorama skylight over rear bed instead of standard skylight 86027 Garage hatch on the driver’s side (left)
86144 Shale decorative surface on media tower “Black Star”
86145 Shale decorative surface on media tower “Jeera Green”
2,011
6
3 1 0.5
0.5 0.5 0.5
0 14 5 4 18 0
31 28 12 7 2 2 2
CP
CP CP
Price on request
413 497 520
520 520 520
412 400 395 269 1,164 580 3,269
1,218 1,084 1,000 408 286 445 857
Interior ambiance “Cool Stuff” (window surrounding in “Spider Champagne”, B-pillar revetment, roof interior and side elements in the rear bedroom in buffalo leather)
10
CP
12 Optional Features
Code Description
Weight
in kg
In package
CP
Price EUR
VAT excl.
SKA front seats instead of Aguti ones (orientable and adjustable in height incl. seat heating and lombart supports). Additional price to Comfort Pack, code 86180
27
86067
86066 Pull-out seat with 3-point-belt in the couch behind the driver and the passenger (registration for 4 persons)
86028 Exterior sliding out storage case on passenger side (right side) 86058 Loose carpet
86029 Darkening pleats for driver and passenger side and front windows 86174 Interior insulating mat for windscreen and side windows
86188 Wall storage textile pockets in the rear bedroom on both sides (standard with “Cool Stuff” decoration, code 86186)
86185 Lowerable and extendible table with additional inflatable roll mattress to turn the couch into a single bed
86153 Additional mattress with Froli bed system between single beds (only for 7.4)
98
18,5 8 6 5 0.5
12 1.5
1,168
1,548
503 600 748 232 75
731 167
86067 SKA front seats 86028 Exterior sliding out storage case on passenger side
86089 Froli bed system
86145 Shale decorative surface on media tower “Jeera Green” 86144 Shale decorative surface on media tower “BlackStar”
Optional Features 13
Gas, Water, Heating
Code Description
86059 Exterior shower in garage
86062 City water supply
86060 Shower tray
86149 Floor heating (only with warm water heating, code 86148) 86143 Fresh water tank upgrade to 200 l
86049 Gas supply connection in side wall
86050 Gas filter (two units) for camping gas bottles
(only in combination with Truma DuoControl, code 86048)
86168 50 l / 20 kg gas tank incl. display
86189 Shelves storage system in the garage instead of gas compartment (only in combination with gas tank, code 86168)
86052 Truma air heating with Combi 6 E heating elements
86148 3020 Alde warm water heating with thermostat. control and heating cartridge with touch screen control panel
86151 Engine heat exchanger (uses the engine cooling water to heat the living area, only in combination with warm water heating code 86148)
86152
86051 Narcotic gas alarm
86054 Inet Box to controll the warm water heating and underfloor air conditioning (SIM card needed but not included)
86061 SOG toilet ventilation
86048 Truma DuoControl CS gas flow control 86192 Ceramic bowl for cassette toilet
Weight
in kg
In package
Price EUR
VAT excl.
1 1 3 5 14 1 1
36 0
0 29
6
1 0
1 2 1
248 272 179 1,202 407 164 171
1,512 0
566 2,328
832 1,465
387 492
248 239 164
Extended heating for warm water heating in the driver’s cab
(only in combination with warm water heating and engine heat exchanger, operable over separate touch screen panel)
3
Electric Installation, Radio, TV, SAT, Navigation
In package
Price EUR
VAT excl.
189 441 353 441 353 293 5,286
in kg
86007 Alarm system (body, drivers’cab doors and garage hatch, control of the interior rooms can be switched off)
86084 Indirect lighting at the media tower (different colours, can be dimmed) 86083 “Green Grass” ambiance lighting in the living room door, can be dimmed 86085 “Green Grass” ambiance lighting in the rear bedroom
86202 “Reed” ambiance lighting in living room door, can be dimmed
86203 “Reed” ambiance lighting in the rear bedroom
86033 Second AGM battery for the body, 95 Ah 86220
3
2 5 3 5 3
27
911
2x 100 AH Lithium batteries (instead of AGM batteries) incl. charging booster, battery monitor and battery management panel (only in combination with combi charger, code 86035)
30
LEP
14 Optional Features
Code Description
Weight
in kg
In package
LEP
MMP / MP1
MMP / MP1
MMP LEP
Price EUR
VAT excl. 2,538
2,345
271 748
1,597
2,176
579 958 496
319 2,933 3,353 1,353 193 662
86055 Underfloor air conditioning (Saphir Comfort RC)
86035 70 A combi charger with 1,600 watt inverter (only in combination with second battery, code 86033 or Lithium batteries, code 86220)
86034 Strengthened battery charger, 32 A
86044 LED 22" television in media tower, incl. DVB-S2- / DVB-T2-receivers, DVD slot and resonance speaker
86040
86197
86037 “Basic” radio precabling, incl. 4 loudspeakers (only in combination with code 86003, electr. exterior mirrors with DAB+ radio antenna)
86038 “Sound-System” radio pre-cabling, including 4 loudspeakers and subwoofer (only in combination with electr. mirrors & radio antenna DAB+, code-no. 86003)
86039 Radio with DAB+, incl. DVD slot (only in combination with radio precabling code 86037 or 86038)
86047 Reverse driving alarm
86041 Oyster Cytrac satellite (without receiver) 86193 Oyster Cytrac twin satellite (without receiver) 86224 160 W solar system incl. MPPT regulator 86036 230 V plug in the garage
86005 Central locking for cab, body and garage hatch
33
12
8 6
5
10
8
MMP, MP1
Navigation system with 9" touch screen incl. Tuner with DAB+, bluetooth and reversing camera behind lily logo (only in combination with radio precabling code 86037 or 86038)
8
86083 “Green Grass” ambiance lighting in living room
at the media tower
86197 Navigation system with 9" touch screen
door
door
Optional Features 15
Upholstery
Code Description
Seat cushions including driver and passenger’s seats
86098 Shadow (textile, anthracite) 86140 Grey (textile, grey)
86200 Green (textile, green)
86099 Temptation (leather, beige)
86100 Attraction (leather, anthracite)
86213 Sensation (leather, brown)
Backrest cushions, style “Kiss”
86101 Grand Cru No. 1, including cushion 40 × 40 cm
86103 Grand Cru No. 3, including cushion 40 × 40 cm
86104 Grand Cru No. 4, including cushion 40 × 40 cm
86106 Grand Cru No. 6, including cushion 40 × 40 cm
86107 Grand Cru No. 7, including cushion 40 × 40 cm
86108 Grand Cru No. 10, including cushion 40 × 40 cm
86201 Grand Cru No. 14, including cushion 40 x 40 cm
86211 Grand Cru No. 15, including cushion 40 x 40 cm
86212 Grand Cru no. 16, including cushion 40 x 40 cm
86111 Beige leather, including cushion 40 × 40 cm
86112 Anthracite leather, including cushion 40 × 40 cm
86214 Brown leather, including cushions 40 x 40 cm
86070 Back covers for SKA driver and passenger seats with practical storage pockets (not available with leather backrest cushions, only in combination with SKA seats, code 86067)
Weight
in kg
Price EUR
VAT excl.
2,008 2,008 2,008
0 0 0 0 0 0 0 0 0
832 832 832
251
0 0 0 2 2 2
16 Optional Features
Seat cushions Incl. driver’s and passenger’s seats
Grey textile, grey Green textile, green
Temptation leather, beige Sensation leather, brown
Backrest cushions Incl. cushions 40 × 40 cm
Shadow textile, anthracite
Attraction leather, anthracite
Grand Cru No. 1
Grand Cru No. 7
Grand Cru No. 16
Grand Cru No. 3
Grand Cru No. 10
Leather beige
Grand Cru No. 4
Grand Cru No. 14
Leather brown
Grand Cru No. 6
Grand Cru No. 15
Leather anthracite
Backrest cushions Style “Kiss”
Optional Features 17
Important Information Technical data Smove
1) The “mass in running order” according to EU directive accepted in VO (EU) no. 1230/2012 includes: the empty mass with standard equipment, driver (75 kg), filling quantities for fuel (90 %), fresh water in driving mode (20 l.), 100 % filled gas bottle, tool kit, Tire-fit and connecting cables. Differences as part of the manufacturer tolerance are possible and allowed.
2) The payload is the difference between the technically permissible laden mass and the total effective vehicle mass. Weights of the optional equipment have to be added to the “Mass in running order”.
3) The permissible total towing weight must not exceed 5,500 kg for AMC 35 L chassis and 6,000 kg for maxi chassis.
4) Further persons are allowed to ride along as far as the technically permissible laden mass is not exceeded and respective seats with safety belts are present.
Important information
This brochure is subject to change without notice. After the copy deadline of this price list (08 / 2020) changes as to models and products, floor plans, technical data, equipments, etc. may have occurred. The illustrations also contain op- tional features, and / or accessories which are not included in the standard equipment and decoration respectively which is not included in Niesmann+Bischoff’s range of sup- ply. Descriptions may have been garbled due to graphic conversion, photographic processing or technical reasons. All data on range of supply, appearance, performance, weights and measures, as well as fuel consumption of the vehicles are in compliance with the knowledge existing at
5) The indication regarding the technically permissible towing weight braked represents a maximum value, which depends on the real vehicle mass incl. persons and load- ing. The technically permissable maximum towable mass shall not be in any case exceeded.
6) All information concerning the total towing weight is valid for a maximum incline of 12% at an uphill start. Weight upgrade (Fiat Ducato Maxi AMC 45H) does not raise the total towing weight.
7) All Smove models with light duty homologation and with 18" wheels can only be registered in Germany with an individual approval. No COC available.
Due to the different materials, manufacturing procedures and light conditions, colour deviations can occur on body- work and attachment parts. Colour deviations do not authorise complaints or warranty claims.
All the dimensions and weights are rounded figures and can vary according to the different homologation directives!
the time of the copy deadline and are valid for all purchase and licensing in the Federal Republic of Germany. Deviations of the values within a range of ± 10 % are possible. The measures of the mattress may slightly vary from the given bed measures. E. g. data on the capacity of the refriger- ators refer to producer information. Prices for optional features are only valid when installed during production. In case of subsequent installation additionalinstallation and servicing expenditures are accrued at cost. We reserve
the right to change prices, construction and equipment with- out notice. With the issue of this brochure all previously issued information and price lists become void.
Imprint
Publisher
Niesmann+Bischoff GmbH Clou-Strasse 1 | D-56751 Polch T +49 2654 933-0
F +49 2654 933-100
M info@niesmann-bischoff.com W niesmann-bischoff.com
Concept + Design
3st kommunikation GmbH, Mainz
Photography
mooi Studios, Mendig BUTTER. GmbH, Düsseldorf
Tech. Presentation + Renderings
Studio SYN, Rüsselsheim
Printing
K+W Kunst- und Werbedruck, Bad Oeynhausen
Last updated: 01.08.2020
Your dealer:
Design diversity
Personality comes from within. The same applies to your Smove. How would you like yours to look? Would you prefer classic-chic or something a bit bolder? No matter what decision you make, you will always feel right at home, as the fabrics and materials are all of high quality.
Build your very own Smove now at:
www.niesmann-bischoff.com/konfigurator/smove
Imprint 19
€90,000 you will need to add €20,000 of options, not a bad price.
Buy in Germany probably get a 15% discount need to allow for German vat only 16% at the moment. So could probably get on the road for around £87,000 at current exchange rates, if the pound recovers to 1.2 that would drop it to 81k.
If you buy from the uk's only importer you will probably pay well over 100k.
Edit will be about 2k less I worked on current German vat rate of 16% price list is at 19%
£71,000 according to website.
Smove
EN
Content
08 Equipment Packs
Smove
Models 2021
• Fiat Ducato 35L
• ESC
control
6.9 Q
7.4 E
Smove Models 2021 3
Driver’s Cab
adjustable
Bodyshell
gel coat sealing
Living and Sleeping
foam concept
mechanism
locking
locking and window
height
dimpled membrane
in each rail
4 Content
Kitchen
Bathroom and Toilet
Heating and Water
Electronics
• AGM battery 95 Ah
overheat
Content 5
Technical Data
Base vehicle
Chassis/Frame
Engine
Output in kW/HP
Chassis / Tyres
Wheel base in mm
Number of axles
Overall width in mm
Seats
Beds
Filling quantities
Fuel tank in l
AdBlue tank in l
Gas supply in kg
Smove 6.9 Q
350 (opt.: 400/450)
2,287
4,100
6,930
2,245
2,770
2,930
1,850 – 2,000
2 (3,4)
895 × 557
1,215 × 577
2,000 × 1,500
90
19
20/140 (opt.: 200)
130
2 × 11
1,140
2,060 × 1,000/1,070
350 (opt.: 380)
71,000
6 Technical Data
Base vehicle
Chassis/Frame
Engine
Output in kW/HP
Chassis / Tyres
Wheel base in mm
Number of axles
Overall width in mm
Seats
Beds
Filling quantities
Fuel tank in l
AdBlue tank in l
Gas supply in kg
Smove 7.4 E
350 (opt.: 400/450)
2,287
4,250
7,430
2,245
2,770
3,020
1,850 – 2,000
2 (3, 4)
895 × 557
1,215 × 577
2,000 × 765/765
90
19
20/140 (opt.: 200)
130
2 × 11
1,140
2,060 × 1,000/1,070
350 (opt.: 380)
74,353
Technical Data 7
Code Description
Price EUR
VAT excl.
12
857
748 580 412 269
2,866
–1,193
Price EUR
VAT excl.
25.5
1,592
2,905
–981
Price EUR
VAT excl.
5,286
2,344 1,353
8,983
–3,403
Weight
in kg
PACKAGE PRICE
1,673
Code 86181
Description
Weight
in kg
86176 Fog lights
86171
Weight
PACKAGE PRICE
1,924
in kg
31
batteries)
incl.
charging
booster,
PACKAGE PRICE
5,580
8 Equipment Packs
Price EUR
VAT excl.
48
958
1,597
748
2,933
6,236
–1,454
Price EUR
VAT excl.
24
958
1,597 748
3,303
–706
Weight
in kg
PACKAGE PRICE
4,782
Weight
in kg
PACKAGE PRICE
2,597
Equipment Packs 9
Optional Features
Chassis
Code Description
Weight
in kg
In package
Price EUR
VAT excl.
2,681 3,689 244
181
0 40 30 0
0 10 0,5
0 1,305 2,815 1,782
86171
7) on page 18
86131
CHP CHP
CHP CHP
CHP
Code
Description
Weight
in kg
In package
CHP CHP
In package
Price EUR
VAT excl.
91
244
832
Price EUR
VAT excl.
3 1
86157
in kg
11
86012
86186
2,011
6
3 1 0.5
0.5 0.5 0.5
0 14 5 4 18 0
31 28 12 7 2 2 2
CP
CP CP
Price on request
413 497 520
520 520 520
10
CP
Code Description
Weight
in kg
In package
CP
Price EUR
VAT excl.
27
86067
98
18,5 8 6 5 0.5
12 1.5
1,168
1,548
503 600 748 232 75
731 167
Gas, Water, Heating
Code Description
86060 Shower tray
86152
Weight
in kg
In package
Price EUR
VAT excl.
1 1 3 5 14 1 1
36 0
0 29
6
1 0
1 2 1
1,512 0
566 2,328
832 1,465
387 492
248 239 164
3
In package
Price EUR
VAT excl.
in kg
3
2 5 3 5 3
27
911
30
LEP
Code Description
Weight
in kg
In package
LEP
MMP / MP1
MMP / MP1
MMP LEP
Price EUR
VAT excl. 2,538
2,345
271 748
1,597
2,176
579 958 496
86040
86197
33
12
8 6
5
10
8
MMP, MP1
8
at the media tower
door
door
Upholstery
Code Description
Weight
in kg
Price EUR
VAT excl.
2,008 2,008 2,008
0 0 0 0 0 0 0 0 0
832 832 832
251
0 0 0 2 2 2
Grand Cru No. 1
Grand Cru No. 7
Grand Cru No. 16
Grand Cru No. 3
Grand Cru No. 10
Leather beige
Grand Cru No. 4
Grand Cru No. 14
Leather brown
Grand Cru No. 6
Grand Cru No. 15
Leather anthracite
Imprint
Publisher
F +49 2654 933-100
Concept + Design
Photography
Printing
Your dealer:
Design diversity
Imprint 19
Base price is €90,000 with 16% vat see my post above.
Click on this for full details. Your right Lenny I should have said € not £
Base price is just under €91,000 then you need to add at least €20,000 of options you could easily add €40,000 without much trouble.
How different we are. We would not consider a mh without a fixed bed, Ready for bed and have to start re arranging things - not for us.
A drop-down is ready to use as soon as it's - er - dropped down? Nothing to re-arrange unless use of the cab seats is important during the night.
Just watching this video, the overcab bed mattress must be at least an inch thick.....
lack of big windows to watch your fellow campers
Wonder who threw the electrics together? I thought I might for once see a professional installation.
That birds nest in the garage is open to damage when the garage is loaded.
Did you notice the kinked water pipe in the service hatch, I know it's probably the prototype they filmed but you would think they would take more care if using it for a promotional video.
I didn't think much of the option of 18" wheels with lower profile tyres, Motorhomes have a hard enough ride as it is.
From that video it looks like you CAN access the toilet while cooking is in progress.
Where do you change to get in and out of the shower?
Is there a wardrobe?
We will not be rushing out to buy one (not that we have the money, anyway).
Gordon
Thats because we share a wife who doesn't do mornings, when I say share a wife I don't mean............well you know what I mean the rest can come to their own conclusions
What is the 2 pin & earth plug on a flying lead for?
It's the Hook up lead, you remove the grey insulated bung that you can see front left and then drop the 3 pin plug through the hole and connect up, the lead is threaded through another insulated bung so that fills the hole (y) for full winterisation.
I would have expected something better on a Morelo seems really crude.
I've never seen any van or caravan wired to any standard at all with one exception: an Adria caravan I bought new in the '80s. The electrics were totally integrated with embedded individual access points for 240v & 12v. The access points were effectively junction boxes and were in the outside wall at the back of the lockers. There wasn't a loose wire in sight anywhere AND it came with both schematic and layout wiring diagrams. Every time I see modern van electrics they look like they were an afterthought.
TBH I worry about the whole concept of building vans down to a 3500 weight limit. It is obviously possible to use lightweight materials but to remain within a sensible price range the best materials aren't within reach of van builders and sound and thermal suppression will be compromised. As well as the strength of internal fixtures and fittings. There's a reason that passenger aircraft are expensive.
I noticed the wheels & tyres too - also the fact that (to its credit) the track width matched the bodywork. Wheels tucked inward of the bodywork seriously detracts from the appearance of most A class motorhomes.
Well it works (y) it's better insulated and tidier than a box on the wall, I know what you mean but its a good and effective solution.
Watch the video again Lenny and you will see the aluminium mesh cover that goes over the whole lot to Hide sorry protect everything, agree about the kinky pipe doesn't look good but might be a pull out for filling or flushing, ours has one but it fitted into clips to form a nice neat loop.
