Ok folks, be patient with me
I have had a self built for the last 8 years ,then bought The Arto a few weeks back.
So it's investigate time and questions come along with that
.there will be more but lets start with 2 things first as it what I have been looking at today.
I'm off to Tenerife on Monday for a wee break
so as we have had a few frosty mornings I decided to empty the Truma combi 6E that the van has ( i have used both heating and hot water and it works fine) just incase of any frost whilst im away and the results are not what i expected,!
I took the bottom door off the wardrobe to have a look as it's tight to get in there and found this.
You can clearly see the pipe is squashed and restricted as it exits the downpipe from the frost valve.
Has anyone came across this before?
Looks like at that angle it should have a right angled fitting on it. It looks like it's always been that way possibly,so will have to figure out how to get that done so it can empty properly in the future.Hopefully there will be enough play in the hose to get at it when I unscrew the valve from the floor.
Any suggestions welcome,bit of a pita really .
Next question
Are these part of a strike back alarm? Asking as salesmen know nothing
I will give van bits a call when I get back from holiday as there is a bit of paperwork that suggests it may have an operating system but not tried it yet till I investigate,just incase I lock myself out or something
.there is alarm fitments on the hab door ,lockers and bonnet.
This last one I found in the bottom of the wardrobe whilst looking at the drain valve, it was stuck to something originally as tacky on the back but cable disappeared under boiler and I can't trace it at the moment . Or could it be a remote sensor the oyster sat stuff is in the wardrobe.
Thanks in advance
Cheers Cris
Next question
Thanks in advance
Cheers Cris
