N&B Arto, here comes the questions!
Pugsy
D&G
N&B ARTO
Since 2012
Ok folks, be patient with me ๐Ÿ˜ I have had a self built for the last 8 years ,then bought The Arto a few weeks back.
So it's investigate time and questions come along with that๐Ÿ˜.there will be more but lets start with 2 things first as it what I have been looking at today.
I'm off to Tenerife on Monday for a wee break๐Ÿ˜Ž so as we have had a few frosty mornings I decided to empty the Truma combi 6E that the van has ( i have used both heating and hot water and it works fine) just incase of any frost whilst im away and the results are not what i expected,!
I took the bottom door off the wardrobe to have a look as it's tight to get in there and found this.
You can clearly see the pipe is squashed and restricted as it exits the downpipe from the frost valve.
Has anyone came across this before?
Looks like at that angle it should have a right angled fitting on it. It looks like it's always been that way possibly,so will have to figure out how to get that done so it can empty properly in the future.Hopefully there will be enough play in the hose to get at it when I unscrew the valve from the floor.
Any suggestions welcome,bit of a pita really .
Next question
Are these part of a strike back alarm? Asking as salesmen know nothing ๐Ÿ˜….
I will give van bits a call when I get back from holiday as there is a bit of paperwork that suggests it may have an operating system but not tried it yet till I investigate,just incase I lock myself out or something ๐Ÿ˜….there is alarm fitments on the hab door ,lockers and bonnet.
This last one I found in the bottom of the wardrobe whilst looking at the drain valve, it was stuck to something originally as tacky on the back but cable disappeared under boiler and I can't trace it at the moment . Or could it be a remote sensor the oyster sat stuff is in the wardrobe.
Thanks in advance
Cheers Cris ๐Ÿป.
Terry
Lincolnshire
Can't remember ;)
I would be tempted to leave it draining as is. If you put a 90 bend on it you may struggle to fit it ( measure) before attempting ๐Ÿ˜‰ Cannot comment on the alarm ๐Ÿ˜‰
Pugsy
Pugsy
D&G
N&B ARTO
Since 2012
Cris, the second photo is exactly the same as the remote used on my Vanbitz Growler.
That's good Peter looks like it has the alarms system just needs tested ๐Ÿ‘
WESTY66
South Yorkshire
Carthago Chic C-Line
All the gear, and no idea!
It looks like a vanbitz remote and the siren bit๐Ÿ‘
However, you will have to chat with AshVanBitz and be prepared to answer questions and provide proof that you now own this vehicle as the alarm will be registered under someone elseโ€™s name, this is NORMAL procedure, so donโ€™t feel put out๐Ÿ‘๐Ÿ‘
Pugsy
Pugsy
D&G
N&B ARTO
Since 2012
I have been thinking I should leave it well alone , might open a can of worms at least it's doing something ๐Ÿ˜.
I should have my Irish passport through soon so the van hopefully won't see much winter weather ๐Ÿ˜Ž๐Ÿ‡ช๐Ÿ‡ฆ.
Upvote 1
Pugsy
Pugsy
D&G
N&B ARTO
Since 2012
Ye I read somewhere before about security questions for new owners. Will give them a call when I get back and hopefully get it sorted and up and running ๐Ÿ‘
Pugsy
Pugsy
D&G
N&B ARTO
Since 2012
Re pic 2.
Can you not shorten the blue pipe to reduce the currently tight angle of the drain hose bend?
Ye possibly or I may be able to lift the valve up a bit and achieve the same result.
Good call never thought about that๐Ÿ‘
Rollingwheels
Fordingbridge, UK
Since 2002
If you warm it with a hot air gun or hairdryer you should be able to fit it inside a plastic elbow of suitable size to help hold its shape and then refit
Terry
Lincolnshire
Can't remember ;)
Hi Chris just be careful with the pipe on the boiler it may have gone brittle over the years - then itโ€™s a case of removing the boiler - donโ€™t ask how I know ๐Ÿ˜ณ๐Ÿ˜‰
Buckinghamshire
Globecar
Since 2010
I took the bottom door off the wardrobe to have a look as it's tight to get in there and found this.View attachment 961027
Next question
View attachment 961053View attachment 961054
Thanks in advance
Cheers Cris ๐Ÿป.
It's just the frost valve outlet that's squashed, right? And has it in fact drained? If so, it will probably keep doing it and I would just leave it alone. It's not an outlet that sees that much action, and it doesn't operate under pressure.
And that does indeed look like a Van Bitz remote. Are there external LEDs, eg in your bumpers? Agree about calling Ash. In the meantime, how they usually work is that the small button on the remote arms and disarms the alarm.
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
If you can't get a 90ยบ elbow then I'd change that pipe for the thin clear stuff as what you have is reinforced & does go flat on tight bends .Whereas the clear stuff is far more likely to collapse less.
Pugsy
Pugsy
D&G
N&B ARTO
Since 2012
Yes I have the dash , front and rear LEDs ,it was all adding up to be a vanbitz system but thought I'd ask the experts ๐Ÿ˜
Pugsy
Pugsy
D&G
N&B ARTO
Since 2012
Pugsy
What model and year of Arto have you got?
Ours is a 69G 2003 and still going strong.
Geoff
Hi Geoff,
It's a 2009 64L ,I have some bits to sort on it but it's a solid van. It will be spot on when I get it the way I want ๐Ÿ‘
Maldon Essex
Our 2009 Arto 74le has drain down taps in the garage.
I turn the pump off open all the taps and shower and then open the drain taps in the garage and it drops the water out off the pipework and the water heater.
Chris
Pugsy
Pugsy
D&G
N&B ARTO
Since 2012
Chris
Ye I looked at the valves in the garage today also,
Got this one and I thought what's that all about , camping or driving mode? The valve behind says hot and there is another tap to the right coming from the pump says cold.
Any idea why it says this?
Buckinghamshire
Globecar
Since 2010
Odd. Probably dumps most of the water and keeps only 20l or so for driving. But then how do you dump it all?
Pugsy
Pugsy
D&G
N&B ARTO
Since 2012
Strange maybe someone will come along and give us an answer ๐Ÿ‘
Terry
Lincolnshire
Can't remember ;)
Where do the pipes run ?
As they are I would say they are both off. It could be the one to turn on for filling the tank. The other to drain ? Just follow the pipe or turn them on and see what happens ๐Ÿ‘
Maldon Essex
It is recommended in the manual you only travel with 20% of the water capacity.
We often travel with a full water tank.
When we drain down for the winter I pull the plug in the bottom of the water tank.
Pugsy
Pugsy
D&G
N&B ARTO
Since 2012
Yes , normally the valve runs inline with the pipe when on but says its in camping mode in that position in the pic maybe as hchris says it drains it down to the 20per cent mode whilst driving if it is inline and in driving mode!! it is going to take a bit of investigation when i get back from holiday .
The joys of motorhoming๐Ÿ™ˆ
Terry
Lincolnshire
Can't remember ;)
How would it know when thereโ€™s 20% left? Or is it 1/5 th of the tank up? We always travel with full tank so would not use the tap ๐Ÿ˜
Pugsy
Pugsy
D&G
N&B ARTO
Since 2012
๐Ÿ˜…๐Ÿ˜… I don't know, the more rum I have the more I get confused ๐Ÿ˜… it is Saturday night after all๐Ÿฅƒ.I can't see the use of the tap you would need to empty the garage each time you drove to access it to change it over๐Ÿ˜….
I'm sure someone knows or I will have to email N&B ๐Ÿ˜
Telford
A class Pilote
Iโ€™m enjoying a rum too that I bought for โ‚ฌ6.80 somewhere in Spain. Like Morganโ€™s spiced but nicer and stronger
