My High Altitude Balloon Flight (1 Viewer)
18,062
48,295
Among the couple of hundred images it took there are only a few looking west towards Cornwall. The far west was covered in cloud but this one still has a good view.
Looking along the coast Salcombe is on the far left then working right there are the estuaries of the Avon, Erme and Yealm. Just to the right of centre is Plymouth Sound with Rame Head jutting out just beyond it. The coast then goes past Looe and Fowey which are not visible but then you might see where a bite has been taken out of the coast. Mevagissey is just beyond this and possibly Dodman Point is visible. In the top right hand corner of the image you can see (just) Cornwall's north coast. Somewhere between Padstow and Newquay I think. Some local knowledge might be useful rangitira :)
This map might help. The balloon was about over the red pin above Dartmoor. The photograph was taken a couple of minutes after the balloon burst so it was probably at around 95,000 feet and coming down under a handkerchief sized parachute. :)
Edit: I've just checked and 95,000 feet is just above the maximum altitude of the SR-71 which is the highest flying "conventional" aircraft. Not many people have flown higher and those who have are often called astronauts. My £4.80 Raspberry Pi did well. I must make it a medal. :)
18,062
48,295
It is getting a bit silly now. The Romanian airforce sent up a couple of jets today to intercept a balloon over Romania. They didn't spot it which isn't surprising as it is what is called a picoballoon. About 36" diameter carrying a 10g payload.
Feb 22, 2011
9,930
20,501
Newcastle under Lyme
Hymer B544 A Class
I read somewhere earlier that the last three the US shot down at huge expense were likely inert decoy balloons 🤷‍♂️
Reactions: DBK
18,062
48,295
Could be but size will be important. If less than metre in diameter then probably a balloon launched by an amateur. Anything in the several metres size possibly not.
However a US company (SBS) make larger balloons which become cylindrical at altitude, perhaps 5m or more high and a metre or so across.
May 13, 2016
1,798
15,926
Elddis Accordo 105
eight years in theory, a newby in practice!!!
Absolutely fascinating. I've always wondered about the temperature at these altitudes and how it physically affects the latex balloons. :unsure:
Reactions: DBK
18,062
48,295
The temperature profile with altitude isn't a straight line. It drops to - 60°C between 10 and 20km then warms up a bit before dropping to around - 100°C at around 100km.
The balloons do keep stretching but the temperature may explain why when they do fail they shatter like an exploding jigsaw. :)
