Should brake discs get hot? | Kwik FitMy front brake disks on my fiat ducato 2.3 2003 seem realy hot is this normal
Probably not if your using your brakes appropriately.Using the brakes indicates you haven't anticipated far enough ahead.
Maybe not but using your bakes is a good thing, it doesn’t mean racing around or speeding but being engaged. Just using your engine to slow is not an a anticipatory driving style.I know we get some who think they are at Le Mans round here but that wasn't what I had in mind.
Im interested in what driving style you suggest ?Maybe not but using your bakes is a good thing, it doesn’t mean racing around or speeding but being engaged. Just using your engine to slow is not an a anticipatory driving style.
Using engine braking also wastes fuel
fI would think most modern cars/van will turn off fuel on the overrun so save fuel.Maybe not but using your bakes is a good thing, it doesn’t mean racing around or speeding but being engaged. Just using your engine to slow is not an a anticipatory driving style.
Because it is cheaper to replace brake pads than a clutch.It's a bit like changing down through the gearbox when approaching red traffic lights, we were all trained to change down, then you were ready to accelerate away when the lights change to green - not anymore. Learners are instructed to approach lights in top gear, putting it into neutral just before coming to a halt.
I never understand why that is a supposed to be a "better" way to drive
The driving style adopted is conditional to the conditions that you find yourself in and adapted to the vehicle you drive.Im interested in what driving style you suggest ?
Anticipating a hazard ahead or red light and lifting off well in advance to allow the engine to slow the vehicle is far preferable to driving up to it then braking surely.
Throttle off, fuel consumption is minimal anyway, what do you recommend, rolling in neutral ?
That’s great, but if the new drivers have been taught to go to the lights/stop/junction in top then throw it in neutral as you come to a halt, they won’t KNOW how to, or even more important it won’t become second nature to use the box. I’ve SEEN a new driver slide through a crossing on a frosty morning by coming up to the crossing in top then brake in neutral, thankfully they was on the other side of the roadThe driving style adopted is conditional to the conditions that you find yourself in and adapted to the vehicle you drive.
Avoidable braking wastes more fuel than many drivers realise. Anticipation also saves fuel. Better to lift off early, and let the vehicle slow down, than barrel along and brake at the last minute. Ideally you arrive at the back of the queue when the vehicles in front are moving again, the lights having turned green, so you are in 2nd gear and not needing to stop at all.Im interested in what driving style you suggest ?
And how inconsiderate... sitting with foot on brake and blinding cars behind with high intensity brake lights. One of my pet hates...Techniques change .... Students now told to sit at traffic lights in 1st gear, with feet on clutch and footbrake.
And how inconsiderate... sitting with foot on brake and blinding cars behind with high intensity brake lights. One of my pet hates...![]()
I have an automatic, downhill I select manual and change down, the box will not let me do anything to harm it and will change gear even in manual if if disagrees with my selection. I was always taught to save the brakes on a long downhill run as if they overheat they will stop working.And as more vehicles use auto gearboxes it becomes a moot point anyway.
Not in a fuel injected car. Freewheeling down a hill uses juice to keep it ticking over. If it's in gear, no need to chuck fuel in.Using engine braking also wastes fuel
So are you saying you were sat at lights with foot on brakes and still got rear ended... or you have started sitting at lights with foot on brake after being rear ended.I'm guessing you haven't been rear-ended by White Van Man while stationary at traffic lights, as I was?
Rear fog lights left on in good visibility - that's a different matter.
I would like to bet if white van man rear ended you he was either... on his phone....checking sat nav.... checking clip board to see where next delivery is... opening a can of ginger and generally not paying attention etc etc. So he would have hit you regardless if wether you had brake lights on or not.
All the more reason not to blind the cars sitting behind youToday's LED ones are brilliant. Hard not to see them.
I meant when approaching traffic lights etc. There's always a need to use engine braking on steep and/or long downhill sections.I have an automatic, downhill I select manual and change down, the box will not let me do anything to harm it and will change gear even in manual if if disagrees with my selection. I was always taught to save the brakes on a long downhill run as if they overheat they will stop working.
All the more reason not to blind the cars sitting behind you![]()
Not really... have to wait anyway for car in front to restart after stop/start stopped it.!And another thing - I wonder if it causes more annoyance to have to wait for the car in front to engage gear (or D which means you MUST put a foot on the footbrake -
I was rear ended, when I spoke with the diver he state that he was 'Still asleep' !! Another time I was rear ended the driver managed to hit me pushing me forward and then a second time (I was starting to thing it was getting personal). The I went to speak to him he started crying and said it was his Mums car ( he was in his mid 30's)!!I'm guessing you haven't been rear-ended by White Van Man while stationary at traffic lights, as I was?
