Motorhome Weights. (7 Viewers)
Jonno1103
1,429
1,607
Harrogate
F Line F70
Since 2012
Current U.K. law on up plating has been changed WITHOUT consultation.
When up plating from 3500kg RFL will continue to be £365 pa. IT IS NOT being reduced to the PHG rate of £165.
Secondly, the DVLA are no longer changing the V5c to illustrate your new weight. The MTPLM will remain at 3500kg. This means that if your motorhome is detected on road installed Weight In Motion Sensors - WIMS, you WILL be classed as overweight. Currently there is no plan to prosecute although you will receive a letter advising you of weight limits etc.
This legislation is causing a great deal of harm to companies such as SvTech who are currently in constant communication with HMG and it is fully expected to be escalated and discussed on the floor in the House of Commons.
However, one of the reasons why in the short term this is in force is due to the EU's 4th directive and once in place will mean that RFL will illustrate the new entry weight limit. Vans & Moho's will need to be over 4250kg in order to qualify for the reduced RFL.
The Fourth Directive...
The EU will ratify this and it will be in force from January 2025. This means that drivers with post 1997 licences can drive upto 4250kg whether EV or ICE powered. Licences will become digital and some medicals will be self assessment.
Current information from Downing Street strongly suggests that the U.K.'s original stance was to also adopt this following an announcement during the March 2025 budget. The U.K. has historically adopted the first 3 directives and will also adopt No4.
There is now however a strong suggestion that this will be announced during the late October budget and will be in place for newly registered motohomes from March 1st.
This is of course still to be confirmed.
Jun 14, 2014
1,657
3,589
Coventry
IH N680CFL
Since2014
This is the thread that has been posted it’s basically highlighting what was posted on motorhome Matt podcast.
Having already spoken with SV Tech today some of what has been said above is incorrect they are in contact with motorhome Matt to correct his statements
But the correct part is the reduced tax has now gone but if you have it already you will keep it
415
315
Lincolnshire
Low profile
I'm a newbie
Very little of what is said above is accurate.
And yes, I have been involved in this farce.
EU fourth directive has NO relevance to this country.
The saga of up plating, has been well documented in other threads - with a lot more accuracy.
It would not surprise me if VED on motorhomes will be set for ALL motorhomes irrespective of weight, same as MOT class is.
