Motorhome Weights. (13 Viewers)
Jonno1103
1,428
1,607
Harrogate
F Line F70
Since 2012
Current U.K. law on up plating has been changed WITHOUT consultation.
When up plating from 3500kg RFL will continue to be £365 pa. IT IS NOT being reduced to the PHG rate of £165.
Secondly, the DVLA are no longer changing the V5c to illustrate your new weight. The MTPLM will remain at 3500kg. This means that if your motorhome is detected on road installed Weight In Motion Sensors - WIMS, you WILL be classed as overweight. Currently there is no plan to prosecute although you will receive a letter advising you of weight limits etc.
This legislation is causing a great deal of harm to companies such as SvTech who are currently in constant communication with HMG and it is fully expected to be escalated and discussed on the floor in the House of Commons.
However, one of the reasons why in the short term this is in force is due to the EU's 4th directive and once in place will mean that RFL will illustrate the new entry weight limit. Vans & Moho's will need to be over 4250kg in order to qualify for the reduced RFL.
The Fourth Directive...
The EU will ratify this and it will be in force from January 2025. This means that drivers with post 1997 licences can drive upto 4250kg whether EV or ICE powered. Licences will become digital and some medicals will be self assessment.
Current information from Downing Street strongly suggests that the U.K.'s original stance was to also adopt this following an announcement during the March 2025 budget. The U.K. has historically adopted the first 3 directives and will also adopt No4.
There is now however a strong suggestion that this will be announced during the late October budget and will be in place for newly registered motohomes from March 1st.
This is of course still to be confirmed.
MisterB
6,842
15,762
Essex
Adria 670 SLT
is it ALL of your post to be confirmed or just bits of it ?
3,297
7,609
Hymer Exsis
20 years
Annoying about the tax, however it’s about time it changed to a sensible limit.
Also means Lucy can drive ours again. :)
3,972
11,266
PVC
1995-2004 & 2017》
There is another thread running on this subject, and on that one it is stated that vehicles already classed as PHGV will retain the £165 rate and not be charged the new rate!
9,976
52,615
Hurstpierpoint. Mid Sussex.
Compass Navigator
Ever since lighting was by Calor gas.
The up plating is already in force.
But it seems that the Gov't website hasn't been updated...........:confused:
822
2,450
Buckinghamshire
Globecar
Since 2010
This will presumably also give a new lease of life to the manufacturers of (slightly) heavier motorhomes who were otherwise going to be squished by a dying client base.
5,842
19,935
Mobilvetta Euroyacht
1996, then break 'til 2011
Won't this mean many up-plated vehicles will be more valuable as it will increase potential customer base?
634
1,292
Rapido
So will vehicles already classified and allocated a tax band remain at that rate? Or will they increase?
Cant see anything on DVLA website relating to this
634
1,292
Rapido
Lets hope so?
They did it with diesel cars, some still only pay £20
257
279
Fiat Based Hymer
OK. So, what is my situation?
We bought a 3650Kg Hymer having had it re-plated to 3500Kg so I could drive it.
Will we need to get it plated back to 3650Kg?
Can we do that?
MichaelT
4,072
8,659
Colchester
Carthago I 143 LE
Since 2016
Ours was 3650 and we updated to 4000 recently and both max permissable weight and revenue weight were changed on V5. So if you like Lenny HB when he get his done he will not get any changes on V5 and still pay higher tax rate?
2,173
5,207
Mid Suffolk
Adria Matrix 670DC
Motorhoming since 2018.
So, if your MH has already been uprated from 3500kg to 3850kg with a current annual RFL of £165, it will remain at £165 RFL for the rest of its life, unless it’s down rated back to 3500kgs. Obviously the RFL would be subject any increase/decrease in line with the annual budget.
Looks like the real winners of these proposals will be owners of those MH’s with a GVW of 4250kgs, albeit with the increased RFL.
Is my summation correct ?
Thanks Derry
822
2,450
Buckinghamshire
Globecar
Since 2010
Can we do that?
You won't have to, no. But if the licence categories change so that you can drive a 4,250 kg van you can, in order to get better payload.
Then you would just be left with any other pros and cons of being above 3.5 t, e.g. on the continent - access to weight restricted roads, speed limits, whether you need a vignette or a box in certain countries, and so on.
Some are more law abiding than others but I generally prefer not to deliberately break laws, so I would probably weigh that up given my travel patterns.
2,407
7,329
Mid Devon
Adria Compact SC
Camping since 1954, MoHo 2022
Double bubble winners will be those already up plated to 4250kg GVW which will remain as PHGV with RFL at £165 (at present).
