Motorhome Pandemic Woes
I was referring though to me fogging my MH with my fogging machine and solution recommended by my virologist client
I thought you said they were a mould/clean air contractor? Thats not the same thing as a virologist!!! Clean air contractors are used to dealing with things like legionella where there are established disinfection/inspection regimes and maintenance measures like running hot water pipes often enough for the heat to reduce the risk.
Then if vehicle has an alcolock it will be disabled for 6 hours,as was a football team's coach last week. At least you know that the alcohol %is high:giggle:
Strangely enough thats exactly the time period I heard for leaving a room after professional fogging!
To date I have had my van 'Fogged' by Alde when in for heating service. When returning to the van, it was too foggy to enter for a few minutes. Secondly by Brownhills in Newark where an operative with a vacuum sized machine 'fogged' all 22 vehicles prior to entering their workshops. The same was done again before leaving the workshops.
Should have been after parked up
