- Jun 18, 2019
- 12
- 2
- Chausson Etape 650
- I'm a newbie
Recommendations for motorhome chocks to support rear wheels when front wheels are on levelling ramps at a site
Can't recommend chocks, but I will say be careful.. if you drive right to top of your ramp, then chock rear wheels you may need to go forward again ( even further up ramp to get chocks out..)Recommendations for motorhome chocks to support rear wheels when front wheels are on levelling ramps at a site
Thank you. It's just the creaking noise with the handbrake on and the gear lever in gear. We have found the motorhome has slipped backwards off the ramps -its a brand new Chausson on a Peugeot Boxer chassis and only 2 months oldCan't recommend chocks, but I will say be careful.. if you drive right to top of your ramp, then chock rear wheels you may need to go forward again ( even further up ramp to get chocks out..)
If the van is not holding on such a shallow slope created by ramps, the handbrake is not setup correctly. Urgent warranty issue from Peugeot as I would suggest it wouldn't hold safely on any hill and thus not safe on road.Thank you. It's just the creaking noise with the handbrake on and the gear lever in gear. We have found the motorhome has slipped backwards off the ramps -its a brand new Chausson on a Peugeot Boxer chassis and only 2 months old
As said, return to Stealer to get Handbrake set up correctly ASAP.If the van is not holding on such a shallow slope created by ramps, the handbrake is not setup correctly. Urgent warranty issue from Peugeot as I would suggest it wouldn't hold safely on any hill and thus not safe on road.
Hand brake needs adjusting? It shouldn't let you slip off?Thank you. It's just the creaking noise with the handbrake on and the gear lever in gear. We have found the motorhome has slipped backwards off the ramps -its a brand new Chausson on a Peugeot Boxer chassis and only 2 months old
