Been for the MOT today. Couple of advisories but it passed. Also the weight was checked of the vehicle is this a new thing at the MOT as never had it done before. Anyone else had a MOT recently
Are you saying that the weight is now recorded on the MOT certificate?Also the weight of the vehicle was checked.
Not seen that before, as I mentioned earlier the weight affects braking efficiency numbers and I only know this from a discussion with a mot tester about our then smart car.Was recorded as a advisory as was close to 3500 kg
yes some testers give a lot of advisories some very fewSo is it up to the individual tester to decide wether it gets put down as a advisory or not ?. Surely they should be a common set of rules
Advisories are often the testers opinion of the condition, I have had a local tester tell me he put an advisory on to make me aware that it will need sorting in the future, which is fair enough in most cases.So is it up to the individual tester to decide wether it gets put down as an advisory or not ?. Surely they should be a common set of rules
How close between the MOT advisory weight and you van plated weight?hi
Yeah I get that my point is there should be a common set of rules followed by all testers. Don't get me wrong it's not a bad thing and I will now go though every I carry which every one should do at some point anywayAdvisories are often the testers opinion of the condition, I have had a local tester tell me he put an advisory on to make me aware that it will need sorting in the future, which is fair enough in most cases.
its not part of the test as such just for brake efficiency for class 4 tests60kg. Can't understand why it has never been picked up on before at any other test station
Was it MOT'd as a class 4 or class7No never had it before and had the motorhome 15 years
As much as I loved our Tandem axled Hymer, if using the French Peage at all it was classed as Cat 4, ie, the same toll charge as a 44 x Tonne Artic.Looks like it's time to upgrade anyone selling a tag axle please
Tester trying to be helpful to let presenter know weight of vehicle, he might not get to meet presenterIf it's not part of the test he shouldn't have put it down as a advisory then?
