Wyaye wires
- Sep 13, 2009
- 3,333
- 9,264
- A class Neisman Bischoff
- since July 2009
Sounds about as useless as all the sergeants I ever came across when I was in the Army...
Sounds about as useless as all the sergeants I ever came across when I was in the Army...![]()
It stows in the master bedroom ( !! ) at the very back.. No where near any wiring at allHope thats it !! Does your table stow behind ??
We had a step issue in our Bessecarr and had to replace the Sargent boxThere is a known issue with a faulty batch of "polyfuse" in some Sargent panels.. Creating an issue with step operation.
This does not sound like that problem BUT may be worth checking with Sargent as they could tell you if your unit is one of the suspect batch..
hope you've sorted it. my step opens and closes ok but the entry door does not always lock and requires key-locking so will strip and check.
Who said that?Sorry about the multiple posts. In France with a very slow internet. Please ignore two, or indeed all of them .
So it's all you're fault that the Rosetta comet lander is having problems!and the awning light is not sending morse code to outer space..
Aw bug***.BTW, who out there was not crossing their ruddy fingers and let me down ?? !!!!
Really confident engineers don't need to cross their fingers ..........................YES !!!!! ( he says with various digits and appendages crossed !!! )
Took the EM50 unit out again and rather than just resolder every bloody joint I took the time to draw up a diagram of it.
Soon became apparent it was either a simple diode or even more simple relay.
Lifted the diode out and it checked out fine..
Put a meter across the relay terminals and that seemed ok too..
But I know relays.. I have spent many unhappy hours taking them apart and cleaning the contacts..
So I removed it complete and put a wee load on it.. Guess what.. got up to 500mA and went open circuit !!!!!!!
Took the case off the thing and with a small contactor file cleaned up the normally closed points.
Slapped it all back together and refitted the board in the box.
Popped out just now and refitted the assembly in the van and hey presto.. worked first time and ever subsequent time too..
Because the original fault was so intermittent I honestly cannot say 100% that it is cured, but finding a good solid fault like that makes me fairly confident it is now a done deal ( though at some time in the future I will replace the relay.. it is just a standard 12v 10 amp PCB mounted jobby so easy to get )
Ladies and gentle folk.. I ask you to keep all YOUR digits crossed for me too !!!!
Cut it off and buy a caravan step from Aldi (specials three weeks ago)
I rather think one is enoughSo it has been over 24 hours now.. I have tried it twice and all is as it should be still
If ( IF ! ) it remains as it should for three days I will then refit the EM50 to its normal location instead of where it is at the moment, propped up agin the wall !
Then, if it starts playing about again, the fault could be fault in the rather interesting loom that goes through the floor !
If that is the case then a whole of of crawling around and working on my back is going to be on the cards by the looks of it..
But one step at a time.. never know.. it MIGHT be fixed !!
