Minxy
- Aug 22, 2007
- 34,744
- 75,235
- Carthago Compactline
- Since 1996, had Elddis/Swift/Rapido/Rimor/Chausson MHs. Autocruise/Globecar PVCs/Compactline i-138
I understand that theory but ... shouldn't it be reading the 'centre' level and not the edge? If so then tipping wouldn't make any difference to the reading as the unit would 'tip' to the same angle as the cylinder and read in exactly the same centre level? Or does the unit read a wider area and therefore gives the lowest reading it gets?The sensor is measuring from the bottom of the cylinder to where the liquid level is.
Try putting a bit of water in a glass and then tipping it to about 20 to 30 degrees and it will give you an illustration of why you get the low reading.
