- Aug 18, 2014
- 26,346
- 160,001
- Transit PVC
- 16 years since restarting
They'd still have to climb through it on mine as the internal door locks have to be removed from the rear of the vehicle.they’ll just smash a window
would this simple mod to make your own work ?Just about to fit ProPlates to my 2018 X290 and I discovered these were fitted. Has anyone else seen them? Are Fiats now strengthening the door locks, and do I need to fit the ProPlates? There is of course nothing on the outside to disuade an attempt to punch a hole beneath the door lock...
Broken Link Removed
Broken Link Removed
They'd still have to climb through it on mine as the internal door locks have to be removed from the rear of the vehicle.![]()
What makes the Ford Transit Mk 8 so easy to steal?Ford are still making the Transit and they are easier to steal l than a Mars bar from a corner shop.
Very true,In fact I often find I unlock the van with the remote only to be unable to get in as the door bars are still in & access is only from the side door, which has a milenco on it outside..Its a good point, but isn't there a risk that they're only going find this out, once they've trashed your window?
I asked the question because every time Ford is mentioned we get the same old response "Ford are so easy to steal". It is interesting that the poster who made this comment earlier has not responded. Older Fords were easier to steal with the Tibbe locks but Ford no longer fit those. Its a shame some keep trotting out the same out-of-date garbage.Not being a thief but I suspect a search in "youtube" will show you.
"Peel and Steal" to gain access should be a good search option.
Then I suspect a OBD reader to reprogram and start the engine.
But I suspect all vans are easy to break into and nick if you are not bothered about damaging them.
I believe you have to cut away a bit of the blind trim. I did see it is a previous thread. I’ll go and look.How do you overcome the plastic cover that houses the side blinds? The videos on YT show the Thule and Heosafe being fitted to Ducato's that do not have these. Hope that makes sense. Thanks
Sorry then, but it looks like the inside to me , with a little corner cut from the Remis blind surround.Thanks. I looked at post #5 but this relates to the external lock. The ones I am looking at are fitted to the inside of the cab doors.
I take on the comments in the forum on the security regarding the damage they do getting in when you have fitted deterrents. My personal take is that a determined thief will just smash anything to get in. But, if they see the deterrents, and we have parked somewhere busy, it will take a lot more effort. Hopefully, this will deter them. Fingers crossed.
Can they do this to an A class?
Not for me... But then again, I am a genius ??I like that solution more than the internally fitted locks. Anyone looking to break in would probably move on to something else that is easier.
I suppose you could dead-lock them on a night too and use the body door to go in and out.
Are they hard to fit?
They really are easy to get in to but wont explain on a forum.I asked the question because every time Ford is mentioned we get the same old response "Ford are so easy to steal". It is interesting that the poster who made this comment earlier has not responded. Older Fords were easier to steal with the Tibbe locks but Ford no longer fit those. Its a shame some keep trotting out the same out-of-date garbage.
Frankly today Fords are no easier/harder to steal than any other chassis make, and there are spates of every type of vehicle theft being reported. "Peel and Steal" only applies to panel vans, and OBD ports an any vehicle are susceptible. Cheap battery angle grinders will defeat most types of clamps and locks.
Rather a cop out, if its that easy it will be detailed in other areas of the web. Tell us how its done so we can take measures against it, or are you just following the Chinese whispers again, and actually don't really know.They really are easy to get in to but wont explain on a forum.
But like any other motorhome you simply force/break a side window.![]()
Have you got a transit or just asking in general?Rather a cop out, if its that easy it will be detailed in other areas of the web. Tell us how its done so we can take measures against it, or are you just following the Chinese whispers again, and actually don't really know.
I have a Transit.Have you got a transit or just asking in general?
That is me convinced that it us the way to go. I might have a practice run if I can persuade the local scrap yard to let me loose on a similar door before I cut into the MH.
Thanks to all for your comments.
