- Jul 7, 2021
- 1,546
- 5,402
- dont own one yet.
Treat it as a showroom of what is possible, what about a system with a double layer of solar panels on the roof with the possibility to slide the top layer on either side hanging off the sides as a pitched roof and thus creating a doubling of capacity?Look what's just arrived
So, RAF Blue Grey finally got Claira's vote
Gone for a very tough military paint with an anti-corrosive primer.
Went with this combo as it's supposed to be very forgiving to use. It can be applied with a brush or roller and should dry flat (bet it isn't that easy). I'm also assured that we can do one section at a time - take back to bare metal, apply primer - and then apply the top coats at a later date without any issue.
Went with a very tough satin black chassis paint to do all the rails etc before a floor goes in. Northernraider did a great job of restoring the chassis and red oxide'ing, so a pretty easy job for us. Also bought a small shot blasting machine to get all the running gear and wheels nice and rust free, before they get a protective coat as well. We have a few tarps that will be taped together to catch the blast media so we can re use it.
I've not noticed any weeps from anywhere, but wanted to seal over the joints in the new panels to be safe. The water leak paint can be applied after the primer and before the top coat. Inside, all joins will be Sika'd or similar.
I'll also fill as many of the dents as I can before top coat. Not going to be too precious about this though. It's a Vario after all
Due to start this on Monday 22nd. Best bit - Claira's doing most of it
(she's way better at painting than me)
Obviously I've been a little concerned about the colour in the summer. But have a solution.
Firstly, insulation. We can get 50mm PIR almost everywhere and the ribs will be spray foamed. Then our usual way of vapour barrier'ing.
Although this should do a pretty good job, I want better than good. So the second thing we are going to add is air-con.
The plan is to get a second hand Eurom AC 2401 over the winter (if anyone has one that's maybe damaged and wants to sell, please let me know), tear it apart, make it as quiet as possible, then build it in to the van body.
We will have one 460Ah LiFePO4 battery from the start, wired ready to add a second before next summer. These, along with 1kw of solar, will mean we can run air con without EHU. It would work with 1 x 460Ah and that much solar, but I'd like more overhead in case of a really hot night, followed by a few really overcast days.
There's still a few things I haven't decided on. Firstly, do I make the solar tilt?
I think with 1Kw tilted we would be solar sufficient all year. But, is it worth the bother of a stronger rack, an electric elevator and electronic locks? The extra structure would weigh around an extra 40kg and I still wouldn't be confident of having it up in stronger winds. The van will use around 2Kw of electric per day and I'm on a fixed tariff at the unit for the next 2 years, so the cost of charging the van in the winter is a maximum of 40p per day. I think I'm leaning towards no tilt.
There's a few other thigs as well, but quite trivial so I won't mention them.
Anyway, we're looking forward to finally making a start on this. Loads of the parts are here, although 3 of the windows don't arrive the UK until the end of October, so not going to be a quick build. But this will likely be our home for the next decade and all that matters is, when it's finished, it's as good as it can be.
