We are currently in France and the temperature is extremely high. We have been running the Maxxfan for long periods and after a while it stops responding and cuts out. Anybody got any suggestions? Many thanks.
Thanks for your reply. You may be onto something there. Yes, beep and green light. The first time it happened we were off grid and we only have a 80 ah agm battery. The fan has difficulty opening and then gives up. This time we are on 10amp hookup and masses of solar. After giving it a rest it responds again.Does it beep and the green light flash when it stops, if so then it's a known problem with the supply voltage to the fan being too low or too high.
Good advice. Thank you. The motorhome is back at the dealer who fitted it so I will get them to sort it out.You can fit a small voltage stabiliser within the Maxxfan casing to stop this problem as I have done with our Maxxfan.
It's a fairly easy job to do and a voltage stabiliser that will do the job is around a tenner, and there are videos on Youtube to guide you on what to do.
Just bought a Maxxfan , apparently they have now cured the voltage problem and it looks like the board may be coated. I will ring them before fitting to double check.
I've emailed the importer with the board number and build date, it's 10-21277KZ, 2024.03That was not the case when I rang the UK importer a few months ago Lenny.
They said that new voltage stable pcb's were under test in the US, and fans with the new pcb's were unlikely to hit the UK before the late Autumn or the New Year.
Ring the importer Lenny rather than a supplier to get a true answer and please let us know if UK supplies date has come forward.
Our Maxxfan was fitted by Rhino five years ago. It's never missed a beat even in the Balkans oven this Spring/ Summer.
Paul Two on Tour just had a thought in the middle of the night like you do.
We don't need to really Stabilizer the voltage just drop the volts a bit so it never goes over 13.8v.
So why not just fit a 6 amp diode like a 6A10 I series with the input as that has a forward volt drop of 1.1v.
Reply from Maxxfan:
Good morning,
The new generations of power control boards, as yours, have been developed to avoid the problems you mentioned.
Thank you, best regards,
Samuel Basso
Controllo Qualità e Assistenza Clienti - Quality Control and Customer Service
Can srl, an AIRXCEL Brand
Via G. Apollonio, 11
36061 Bassano del Grappa, Italy
Tel: +39 0424 1953311
Cell: +39 324 550 6994
www.airxcel.eu
www.cansrl.com
Mine hasn’t missed a beat thankfully and I haven’t fitted anything that lowers the voltage.
Gave them the board No. & date, and their reply.Your reply is not from the UK importer Lenny.
Are they actually in stock with the UK sellers yet ?
How are you going to know that you are not buying old stock ?
I have to be honest and say if it stopped tomorrow, I can’t complain. I have used it virtually every day I use the motorhome.Yet ..,....
I’m hoping this is the case as I’m due to have one installed in a few weeks.Just bought a Maxxfan , apparently they have now cured the voltage problem and it looks like the board may be coated. I will ring them before fitting to double check.
This has been a concern of mine and I’ve not even had it fitted yet! How easy is it to clean, and do flies get stuck inside and then leave you with their sad scattered bodies on display?!Not related to the problem but has anyone ever noticed the gunge that builds up on it. While cleaning the van I've always overlooked it till the other week when it caught my eye. I was shocked to see it
Very easy to clean, fan comes out easily with an Allen key and you can wash it down and wipe the rest.This has been a concern of mine and I’ve not even had it fitted yet! How easy is it to clean, and do flies get stuck inside and then leave you with their sad scattered bodies on display?!
I’m quite seriously wondering whether to revert back to the (cheaper) plan a, and fit a Heki instead!
Never seen a single dead fly. It feels like a thin coating of grease which wiped off with a small sponge with a basin of hot soapy water. Saying that it took 6 years to build up so I wouldn't worry too much, not a major problemThis has been a concern of mine and I’ve not even had it fitted yet! How easy is it to clean, and do flies get stuck inside and then leave you with their sad scattered bodies on display?!
On my one you just turn 4 plastic latches to release the grill, eairler ones you needed an imperial Allan key.Very easy to clean, fan comes out easily with an Allen key and you can wash it down and wipe the rest.
Yes, sorry, I wasn’t clear. The grill comes off with latches. The fan rotor is secured with an Allen key.On my one you just turn 4 plastic latches to release the grill, eairler ones you needed an imperial Allan key.
Thank you all for your reassurance!On my one you just turn 4 plastic latches to release the grill, eairler ones you needed an imperial Allan key.
