Personally I don't think I'd trust a max fan with no screws . They fit completely differently from a heki style vent . There's no sandwich effect with a max fan, the size of the dome and the fact the fan operation is bound to cause vibration and slight movement I think it needs screwed aswell as mastic.If I was fitting one it would be non setting sealant and no screws or not fit it, why wouldn’t that work?
I’ve put large rooflights in with just non setting sealant, probably a lot heavier than the maxxfan.
Can't see the point of the strips if there was enough force to lift the vent from the adhesive the thin ABS sides the strips are mounted to would just shatter.Couldn't quite work out how he did those strips, but applaud doing it that way. I've seen cheaper Fiamma skylights that have loads of screws around the top flange like these Maxair's have and it's messy and asking for leaks. So many holes and not necessary when clamp mounts work better. A bit surprised they use that method (screws).
The dome is only held on with 4 self tappers into spire clips on the thin ABS sides, any problems they would be the first to give way the plastic would split without much force on it. Really don't see the need for screws providing a decent selant/adhesive is used. You would only need screws if you use a buytal mastic.the size of the dome and the fact the fan operation is bound to cause vibration and slight movement I think it needs screwed aswell as mastic.
I am going to try and use the original blind when I fit mine...All fitted easier than I thought has anybody managed to adapted the original blind to fit.
Clever stuff...I decided to go blind less...delighted with the Maxxfan...very efficient and is going to be very useful next summer...Just 3d printed a replacement manual winding knob to stop the blind hitting the original one.
Are you selling these KelvJust 3d printed a replacement manual winding knob to stop the blind hitting the original one.
Sorry if I've missed any updates Lenny but did you get around to fitting this and if so, did you just use Sika?Can't see the point of the strips if there was enough force to lift the vent from the adhesive the thin ABS sides the strips are mounted to would just shatter.
I will be fitting one the the new van I will just use a good quality sealant/adhesive, no screws. My sat dish is still on the roof after 5 years only stuck on with Sika 292i.
Don't be silly still waiting for the van now gone out to Feb delivery.Sorry if I've missed any updates Lenny but did you get around to fitting this and if so, did you just use Sika?
Oops! SorryDon't be silly still waiting for the van now gone out to Feb delivery.
Are you selling these Kelv![]()
Sorry not selling them my son 3d printed it for me there are a few funsters on here that do 3d printing maybe one of them can helpAre you selling these Kelv![]()
