We're the same in fact we managed without any solar the first few years and never had a flat battery although if it turned cold it wasea worry as we have a diesel heater that uses a fair amount of battery on start-up. The op does say though winter lighting which suggests to me winter use and solar then being more tricky. What he doesn't mention is if it's likely to be a compressor fridgeDepends on your usage patterns. I have one 175 watt and have never run out of power (or anywhere near). The only reason I might want more is if I stayed put for more than 2 weeks and the sun wasn't shining. (I wouldn't go somewhere for 2 weeks if the sun wasn't shining!) We tend to move around a lot and travel April - November. Mostly in southern Europe. So for me buying more would just be waste of money.
In addition to Lenny's comment, I think you'll find you won't have enough "real estate" up top to service your requirements, other than in summer.
.... charge rate at idle no matter what the sun is doing.
Edit: I wouldn't advise going to a Solar only Specialist, go to someone like eddievanbitz who can advise you on both Solar and B2B charging systems.
Red
Over kill! There is nothing in his list there that uses much power (assuming the lighting is LED). I can stay off grid for a week (not moving) with 175watt and 180 ah of AGM (effectively 90 usable). The only problem would be if there was no sun.
Most people would struggle to do that with that setup.Over kill! There is nothing in his list there that uses much power (assuming the lighting is LED). I can stay off grid for a week (not moving) with 175watt and 180 ah of AGM (effectively 90 usable). The only problem would be if there was no sun.
What fridge then? Examples? Almost all now fitted with Dometic or Thetford.We're the same in fact we managed without any solar the first few years and never had a flat battery although if it turned cold it wasea worry as we have a diesel heater that uses a fair amount of battery on start-up. The op does say though winter lighting which suggests to me winter use and solar then being more tricky. What he doesn't mention is if it's likely to be a compressor fridge
Heres a Thetford compressor fridge https://www.jacksonsleisure.com/fridges/thetford/t2138-12v-compressor-fridge-freezer/What fridge then? Examples? Almost all now fitted with Dometic or Thetford.
