Maxfan (1 Viewer)
Trout bum
567
584
Ayr
Adria Matrix M670SL
Has anyone replaced there sky light with a maxfan ?
Trout bum
Trout bum
567
584
Ayr
Adria Matrix M670SL
Thanks for reply but more looking for someone who has changed there original skylight for a maxfan on their Adria motorhome ,
Oct 9, 2019
5,081
17,906
Todmorden
Van conversion
FUNSTER in a PVC
No fitted new one to new aperture, whats the problem ?
Feb 13, 2013
1,015
1,116
Edinburgh
Rapido 881F
Since 2015
Is there a specific reason that it has to be an Adria?
I have replaced our skylight (mini something) with the maxxfan deluxe. Is there something specific you want to know?
Trout bum
Trout bum
567
584
Ayr
Adria Matrix M670SL
It's to see if it will fit existing skylight with no cutting , and somewhere I read that the Adria,s were pre-wired for roof fans , so was hoping someone on here had undertaken this task to see how it went
Oct 9, 2019
5,081
17,906
Todmorden
Van conversion
FUNSTER in a PVC
Possibly it’s because according to his avatar, that what drives ?
Feb 13, 2013
1,015
1,116
Edinburgh
Rapido 881F
Since 2015
If you identify the existing sky light we should be able to tell you if the fan will fit. Mine was straight remove and fit the maxxfan. No extra cutting etc required. Given that most skylights are a common component for all motorhomes you may be in luck. (just checked ours was a mini heki delux 400 x 400 roof hole)
If you go ahead there is an article, I think I posted a link to it, taking one though the installation without the need for screwing on to the roof which I was not happy with.
Trout bum
Trout bum
567
584
Ayr
Adria Matrix M670SL
I'll measure it and see if there's any identification on it , I'm sure I read somewhere that the Adria motorhomes had been pre wired for a roof fan this would save running a cable to it
Aug 6, 2013
12,035
16,719
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Most small rooflights are 400 x 400 - I'd be surprised if yours is different. If you remove the inner frame the size & whether it's pre-wired should be visible.
Trout bum
Trout bum
567
584
Ayr
Adria Matrix M670SL
Thanks for the info I'll give it a go and see what I find
Jul 27, 2013
959
4,446
Wilts/Oxon border
Van Conversion
Since childhood!
Yep. Replaced a Mini-Heki with the MaxxFan Deluxe. Straight swap (apart from adding a wire).
EDIT: Just on the off chance you are wondering about doing the same, I videoed a lot of the install:
I know this is an ancient thread, but just a quick thanks for this video. I've been looking to put a heki roof light in my van's forthcoming new roof, but now I'm thinking the MaxxFan would be a better choice. My only concern is how much it stands proud of the roof.
WESTY66
6,545
16,648
South Yorkshire
Carthago Chic C-Line
All the gear, and no idea!
My concern is how do you get wiring to it without trunking across the roof🤷🏼‍♂️
Jul 27, 2013
959
4,446
Wilts/Oxon border
Van Conversion
Since childhood!
Presumably the same way as the supplying company gets wires to the lights which are installed in the roof?
Jan 22, 2013
1,334
70,688
London SE
A class Adria vision I707
since 1971
I used a long piece of studding , ground the end to a cutting shape and used it to cut through the insulation, shortest route to a roof light, took longer to do than fitting the Maxxfan,
But all perfectly doable, I now have one at each end of the Motorhome for maximum efficiency,
May 30, 2019
770
1,093
Aberdeen, UK
Adria Twin Supreme
Since 2018
The Adria Twin is pre wired for mains air con unit so it’s easy. Check if it’s a factory option for your van, if it is you could find wires already there.
CAB96
1,153
2,195
Stockport, UK
T6 Leisuredrive
Intrigued! New roof?
They do look a bit taller than a standard fan.
Jan 22, 2013
1,334
70,688
London SE
since 1971
That’s only if you open them to gain maximum ventilation, they will still function closed, how many skylights can you leave open in the rain without getting the interior wet?
Well you can with the Maxxfan and also have it open automatically to your preset temperature,
MichaelT
3,708
7,604
Colchester
Carthago I 143 LE
Since 2016
What is studding?
Jul 27, 2013
959
4,446
Wilts/Oxon border
Van Conversion
Since childhood!
New roof is strongly likely. I’ve just had a quote. Existing roof is a good make and works fine but I’m reaching the point where practical day to day use without having to mess about with the roof (esp as I use my van year round) is beginning to defeat the better aesthetics that the pop top gives.
