- Aug 7, 2024
- 1
- 1
- Iveco Daily Conv
Hi, hope you can help. I have a Shurflo Trailking water pump, 7 lpm flow rate. Can I use this in my water system with a tankless water heater that operates at 10 lpm flow rate?
I'm not sure if it's best to exchange the pump for a higher flow rate?
Or downsize the shower to a 5 lpm flow rate? But will a 7 lpm pump be too hefty in this scenario?
When reading the tech specs, the pump says 30 psi and the shower is rated for 20-80 psi, so I don't think the pressure will be an issue.
The pump will also be supplying one small sink. We won't be using both at the same time.
Many thanks, Lottie
Many thanks, Lottie
