Saltings
In the end we opted for a new battery and that seems to have solved most of the problems. However we have used EHU's a lot to power the fridge etc during the last few weeks so I can't say if we have solved the solar cell charging problem yet. I will see when back in the UK. We were lucky as our insurance includes home start and we needed that to get someone out to help to remove the drivers seat. Hab. batt. is under that seat.
One tip I picked up was to ensure that the wiring to the solar charge controller is correct. On ours
as shown below - 1st 2 terminals from the solar cells 9reads about 20v in daylight), 2nd 2 MUST be for the Hab. batt. (70% of charge) and final 2 to motor battery. Last two to read about 12.7v.
2nd tip was to add + & - wires from the new battery terminals to an easily accessible point under front seat. That way we can always run a trickle charger in an emergency direct to the hab. batt. Thist was previously impossible to do.
Hope that helps a little.
Saltings
Saltings
