LPG guages
Zefiro 685
Hello
Newbie here.
Just become the proud owner of a 4 year Rollerteam Zefiro 685.
Have been using lpg a lot in the last week having survived my first fill.
I was advised that the bottles are "wired" so they both empty at the same time but from the gauges this doesn't seem to be the case.
Advice please.
Looking at the picture, I may have to follow up with a better one.
suavecarve
Surrey/Hants
Dethleffs Trend A
July 09
I think most of us to tend to ignore (or take an indication) from the gauges.
I really wouldnt want both mine being depleted together.
We just sold our RT685 so know the van quite well. We just turned off the smaller of our 2 bottles. When the first one ran out we had enough to find some more. The larger bottle would last us 3-4 weeks in France in the summer mainly running the fridge/freezer.
Bolton
Hobby T500 LHD
Spring 2024
Yes I would turn off the rotary knob on one or other bottle leaving the other almost full. Then all you would have to do when the bottle in use runs out is a quick trip to the locker then turn one knob off and the other on. With luck it will not be raining when you do that!!! If you are especially vigilant and watch both the gauges and the weather forecast you could even swap bottles before the rain pours down overnight.
stewartwebr
Edinburgh
Morelo Empire Liner
36 years and 16 motorhomes
Another vote for one valve closed. Both open means you learn you have no gas when both are empty. One closed means you swap over, still have gas then refill the empty one ASAP
hja
Lincolnshire
Globecar Summit Prim
Since 2019
We have two cylinders. We were told by the supplier to open both cylinders. But we have a dial at the top that points to one or the other. We are using from the one it points to. Never been sure why we open both, but only one depletes.
Lenny HB
On the coast in West Sussex
Carthago Compactline
Because you have a changeover valve.
Your one appears to be manual so when one bottle is empty you change to the other one.
Ours is automatic and we get a light inside the van that tells us bottle has changed over.
  • Informative
Reactions: f6c
Lenny HB
:welco:
As said best to keep one bottle turned off until you need it then you know it's time to refill.
After filling always swap bottles this prevents a possible over fill.
Your gauge only works from when the bottle is about a third full it won't register until then. Only registers from a 1/3 until empty.
  • Informative
Reactions: f6c
Pembrokeshire, UK
Auto-T Expedition 66
Not in my experience. I'm impressed with how accurate and useful the Gaslow rotary gauges are. Both our bottles give very linear readings from full to empty.
Reactions: f6c
JockandRita
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Hello
Newbie here.
Advice please.
As you don't appear to have an auto changeover valve, both cylinders will deplete together, so the advice to keep one closed is correct and useful.
In the height of winter with Alde heating on 24/7, the full cylinder will last you around 5 - 7 x days. As soon as one cylinder is empty, fill it up ASAP.
Filling up on the way home after a trip out, means that you are ready for the next trip, and the same with diesel. (y)
HTH,
Jock. :)
