LPG fill point where? Not a inside or outside question.
Northampton
Rapido & Bongone
Not a inside or outside question. On my 604 the obvious place is in the skirt between the Hab door and gas locker. Is the skirt strong enough? Does it need a plate behind skirt? where have you fitted yours? Another place suggested was the towbar, rear face or side facing. This would be at least 3m to the locker, needing a connector. Any comments. Yes inside the locker would be easy.
Inside can cause issues with attendant on forecourt stations, if you check your skirt I’m pretty sure you will see strengthening struts I have put mine along side to avoid flexing when filling it works perfect for me
Dave Newell fitted my LPG filler here on my Rapido 646. No strengthening needed, ABS is strong enough here.
Our LPG is in the gas locker door. Plus one ordinary tank. Just in case we are unable to find a LPG station.
Ours is in the skirt without any support but the skirt is aluminum.
Techno fitted a bracket from the filler to the chassis on his Rapido..
Mine's fitted in skirt just below gas locker. Rapido 785f.No need for strengthening
So really it is an inside outside question.....my thoughts
Would never want a long filler hose....from the towbar ?????
Locker door.................loosening whenopening and closing
Inside .............................risk of being refused when opening
In the skirt...................overcomes ALL of above.......why not
Remember to paint or use sealant to fit the gaslow point hole edge as the aluminium will oxidise and the paint will bubble over time if left unprotected.
Mine is in the skirt but center rear is a great option fill from either side
I plan this in the new year, I will be fitting filler in the gas locker and see how I get on. Can always move it into the skirt at a later date if I have any problems and will be easier to move to another van in the future.
When I did mine, I made backing plates of 9mm ply glued at the back, sandwiching the body panel. For the gas, ehu and water fill up, it helps with flexing of the body panel.
Like others ours is in the locker no problems so far after 5 years.
Thanks for the resurection.
I have fitted mine in the locker, with the intention of keeping options open.
The only problems so far have been with a large Shell shield interferring with the locker whilst rotating. I've used a 90 degree bracket in the cupboard. The silver grey plastic is quite flimsy. To the right of the locker is the cab
tmp-cam-4581433080574171169.jpgnot attached to last post
In the skirt ours is alloy and it is very rigid but only used the small black type you have a job to even see it in my picture
Our filler is on the top of our Gas Locker door great as I find bending difficult
Had it inspected when fitted the gas fitter had no problems
filled up all over Europe without any problems
Mine is in the body next to the gas locker door. All pipework within the locker which is wider than the door.
