Steve and Denise
Nothing wrong with the old accumulators, here in Lincolnshire not that many years ago (1989) some out of the way houses still had generators and accumulators.
- but hardly noticeable?More efficient too. If you are trying to harvest solar you waste 5% charging a lead acid battery (LiFePO4 only 1%) and if you are using something like a big inverter the higher Peukert’s exponent of lead acid also eats into your reserves.
agree that rate of charge would be an immediate benefit, if it matteredWeight is a bonus, I find the rate of charge and depth of use is where the real value lies . and that is immediate too.
depth of discharge would depend on compared available capacity
I’ve not made myself clear.So now from waiting years to see the valueyou now agree that
The weight benefit is immediate, if it matters
The rate of Charge is an immediate benefit, if it matters
But you say discharge would depend on compared availability. Why?
Given two 100AH batteries, one lead acid the other Lifepo4
The depth of discharge on the Lithium would be immediately apparent. It will give more useable amp hours between charges.
No waiting for value at all, they are all considerable benefits that are immediate.
Lots of people look for reasons not to buy, but if Lfepo4 batteries were the same price as lead acid, most everyone would have them, and why not , the benefits are many and immediate.
If the selling point is that Lithium outlasts Lead, we’re buying on a promise. It’s one I’m prepared to believe but I still have reservations about the actual life expectancy compared to what’s been claimed.
by the fact the batteries don't reset themselves when the temperature gets well above freezing.
Lol OK did Van Bitz install them? If so we can narrow it down to Sterling, Victron or DometicSorry they could be Victron.
The 4% charging difference is self explanatory and perhaps not important to some but the Peukert factor can make a significant difference under load. My Victron battery monitor suggests setting the Peukert Exponent to 1.25 for a lead acid battery and 1.05 for a LiFePO4 one. With a battery capacity of say 100Ah and a draw of only 1A both batteries will perform the same, however if you increase the load to 10A the lead acid one will reach the 80% discharged point 2.5 hours before the Li one.- but hardly noticeable?
My Relion ones are ok to discharge down to -20C and they have never shut down. Charging below 0C has to be restricted but it should not affect normal discharge.Problem is when the temperature drops to below zero the batteries close down.
I’m not influenced that much by the price.Ahh You're talking price. I bought for the benefits I outlined above, knowing those benefits came at a price. Even If they didn't last as long, I would still buy, to get those benefits, weight, rate of charge, depth of discharge.
I'd guess that it's the battery management system that's doing this.I had 3 x 100amp lithium batteries fitted this time last year. They've been superb im really pleased with them. I have come across a problem since lockdown though.
My van is in storage as it can't be used. The van is set up with a battery master that charges the vehicle battery. Problem is when the temperature drops to below zero the batteries close down.
The van is fitted with WiFi and I lose the cctv cameras as everything shuts down. I get a message telling me the vehicle battery is down to a low level. I then have to go to the van to start it up.
This is a real problem and isn't helped by the fact the batteries don't reset themselves when the temperature gets well above freezing.
I have to go to the van and start it up before the batteries kick into life again. I thought about wrapping the batteries in insulation to protect them from the cold but was worried about fire risk.
Anybody else come across this problem? How did you resolve it?
There are many types of lithium batteries with very different chemistries. You will not find the LiFePO4 type used as leisure batteries in many other applications because they do not have the energy density needed for portable devices.I have some lithium-powered devices in which capacity has fallen-off unexpectedly.
I think there are many types of Lithium chemistry being used for leisure batteries, too.There are many types of lithium batteries with very different chemistries. You will not find the LiFePO4 type used as leisure batteries in many other applications because they do not have the energy density needed for portable devices.
As far as I know the only Li chemistry used for motorhome leisure batteries is LiFePO4. Some have cylindrical cells and some prismatic, the BMS arrangements may vary too. Li batteries with magnesium, cobalt, nickel and manganese chemistries are in regular use for other applications.I think there are many types of Lithium chemistry being used for leisure batteries, too.
Even more if you include integrated BMSs.
I don’t think so, the voltage is a dead giveaway. If there was different chemistries, it would reflect in the pack voltage. What we see here, is the LiFePo4 all over, which is the closest to lead; hence some say a drop in replacement. No other chemistry is so close to lead. Different construction yes, prismatic and cylindrical cells, different grades and different make bms. Some battery builders make their own bms, some buy ready made and just program the settings.I think there are many types of Lithium chemistry being used for leisure batteries, too.
Worse case scenario...The lithium (LIFOS, LiFePO4) leisure batteries were both fully charged (100% on the Bluetooth App) but the engine battery was flat
Not necessarily. Lithium batteries charge much better giving almost all the energy put into them back. Lead acid batteries are a glutton giving only around 80% of the energy back that you put into them.Not wishing to knock Lithium, they still have finite capacity.
If the difference is so noticeable, my guess is that the old battery was due for renewal.
Let's not get carried away with the euphoria
Their value will be discovered in later years.
Try as much as 20%If you are trying to harvest solar you waste 5% charging a lead acid battery
Well, I thought I'd seen some other Lithium chemistries but I cannot find them now!
I'm sure I didn't dream it, but maybe it was in power banks or EVs...
I'm sure the early Lithium leisure batteries did not include Phosphate but I was thinking of compositions that had come into use since then and which sounded even more promising.
