He hasn't got to the crest of the hill yet ?Hasn’t been back since the first post to check on the answers![]()
We had a Commer Highwayman with a Perkins P4 to go up Shap it was first gear We could have walked up quicker ,mind you it was 1968I had a Bedford CF motorhome like that. The temperature gauge would go into the red just as we reached the top of one particular hill in Wales![]()
Is it brand new? When I got my new motorhome I had real problems going up steep hills. To the extent that I thought I'd made a terrible decision in engine choice However once the engine had run in a bit and loosened up it became a lot better. Plus I learnt how to sort of drive it better and give it a bit of welly/revs. It's now after 20k miles a much nicer drive.First outing in our Benemar Tessoro 486 170 bhp. It is losing significant power on inclines. Never had a motorhome before.
Like you find travelling at 60 6th gear in Cruise mode rarely have to change gear for hills. 2.3 140bhp Ducato Autotrail up plated to 4T.Stick the cruise control on , works for my Moho better than not having it on. No idea why ?!
Fiat 130 Ducato is most efficient at around 2200/2400 RPM
Changing gear keeps the revs in prime condition and returns the best MPG as well. Engines like a good rev now and again to clean out the DPF.
I would guess Fords have a hotspot as well
Phil upmetank
No the turbo is different and on the Euro 6 engines I think the gear ratios may also be different.Has anyone had their engine remapped? Autotrail Fiat Ducato 2.3 130Hp. I've been told that the engine and turbo is the same for the 130 and 150 Hp variants and only a setting (changed via a laptop) will give better economy as well as more power. Not sure about the 180 Hp version though.
Would this invalidate insurance (even if I told them)?
Yes, same engine, wish I'd done it years before. Upgraded 130bhp to (the guy said) 158bhp and it was immediately apparent with much improved torque, which is what I asked for, making it much better to drive with less gear changes. Didn't do much for the fuel consumption, probably about 2-3mpg but that's 10% so okay - I haven't changed my driving habits so probably realistic.Has anyone had their engine remapped? Autotrail Fiat Ducato 2.3 130Hp. I've been told that the engine and turbo is the same for the 130 and 150 Hp variants and only a setting (changed via a laptop) will give better economy as well as more power. Not sure about the 180 Hp version though.
I have had my 2.3 130 2012, remapped about 6 years ago.Has anyone had their engine remapped? Autotrail Fiat Ducato 2.3 130Hp. I've been told that the engine and turbo is the same for the 130 and 150 Hp variants and only a setting (changed via a laptop) will give better economy as well as more power. Not sure about the 180 Hp version though.
I still think you should give the engine a good blast frequently to clear the DPF.Our first new-to-us motorhome would lose power on inclines. An investigation revealed that there was too much carpet under the acceleration pedal so the turbo could never kick-in. An easy and cheap fix to this problem - just remove some carpet!
With subsequent motor homes we have had installed a plug-in Torquing Diesel module which greatly improves uphill performance.
I'm having my Peugeot HDi 130 remapped this week and have contacted Comfort insurance to ask if this would compromise the insurance cover. They said they weren't concerned about it and it would not alter my premium. They also said that I should tell them when I have it done just to update their records.Has anyone had their engine remapped? Autotrail Fiat Ducato 2.3 130Hp. I've been told that the engine and turbo is the same for the 130 and 150 Hp variants and only a setting (changed via a laptop) will give better economy as well as more power. Not sure about the 180 Hp version though.
