Loose tap in bathroom (1 Viewer)
Feb 22, 2016
3,674
11,268
York
Bailey 620 Approach
While cleaning the van, noticed that the tap, which moves so that the spout can be positioned, is quite loose. I looked underneath the basin and there is a bolt that seems to hold the bade of the tap in place. Trouble is that the gap between the basin and the bolt is too narrow to allow access with a spanner.
How can this tap be tightened? Taking out the basin seems a bit drastic. šŸ¤”
17,672
43,584
I use a deep socket on a flexi shaft
Ingwe
Feb 22, 2016
3,674
11,268
York
Bailey 620 Approach
Socket on an extension?
It would need an open spanner on an extension unless I can remove the supply pipe first before using a socket on an extension. Struggling a bit to visualise how Iā€™d do it.
Apr 22, 2018
6,873
12,682
Herts.
Adria Coral lowline
Can you get a pic of under the tap?
Is it a big nut that goes around the body of the tap, so has the two pipes through the centre of the nut?
Ingwe
Feb 22, 2016
3,674
11,268
York
Bailey 620 Approach
You need one of these, excellent piece of kit!
This looks like it may be the tool of choice but I need a good read of the instructions to see how to use it! Looks quite tricky. The two pictures below seem to be the most likely.
Lizbiebrowne
362
447
Teesside
Hymer B654
Since 2019.
I have a similar loose movable tap that I found, despite looking impossible, I could get my hand onto the nut and tighten. I just canā€™t just tighten it enough to make it fast.
Dec 30, 2019
371
289
Manchester, UK
Burstner t700
Early 2019
Same here, big nut that holds tap in place, got it hand tight then got a long slotted screw driver and hit the nut with the screwy with palm of my hand just enough to give it that little bit more seems to have done the trick for now.
Hope this helps
Ingwe
Feb 22, 2016
3,674
11,268
York
Bailey 620 Approach
This describes perfectly what I can do. Can reach up with hand but canā€™t get to properly tighten with my fingers. A crappy, lightweight little basin and poorly designed so access is difficult with the basin in situ.
Ingwe
Feb 22, 2016
3,674
11,268
York
Bailey 620 Approach
Looking again at the picture, a socket that fits onto a screw driver handle with or without a ratchet thingy looks like it might be able to get over the nut.
Apr 22, 2018
6,873
12,682
Herts.
Adria Coral lowline
Donā€™t think I have the clearance.
That type of fitting is standardly done up with the box sockets that are listed in the Screwfix link in post 4.
Itā€™s a standard kitchen monoblock type, not a motorhome style fitting.
Aug 22, 2007
2,570
33,763
essex
2017 sunlight t69s euro6
Either a box spanner or a socket on an extension from the photo it looks fairly easy 10 or 12 mm
Ingwe
Feb 22, 2016
3,674
11,268
York
Bailey 620 Approach
well done sir, looks a like a must have tool.
one winging it's way to chez moi.
When you get it, please report back on how easy it was to use. The instructions on the Amazon posting look Double Dutch to me. But Iā€™m not great technically. šŸ™‚
Ingwe
Feb 22, 2016
3,674
11,268
York
Bailey 620 Approach
Will be going to Screwfix as soon as weā€™re back in May for the box spanner in post #4.
Feb 8, 2023
68
139
Rainhill
Knaus 650 Sun Ti
moho since 2012
oh I'll never use it, just sit in my tool box forever:LOL:
actually all taps are tight, but I'll give a go and feed back
Frank
Jan 29, 2017
692
562
Gloucestershire
Lunar Champ H621
15yrs
IF the centre nut clamps the C shaped peice then i think youll find its an 11mm nut.
I managed it with a tubular spanner under our kitchen sink, a perisher to get at, needed a torch and a mirror.
Check thesizes in the screwfix kit to confirm it
Mike S
Ingwe
Feb 22, 2016
3,674
11,268
York
Bailey 620 Approach
Mike S
Just checked and it includes a 11mm socket. From their (Screwfixā€™s) ad:
PRODUCT CONTENTS​
3 x spanners (8 x 9, 10 x 11 and 12 x 13mm) and tommy bar.
Mar 23, 2012
9,655
32,550
sleights
c class
If it's screwed to a bit of worktop I'd first loosen it off lift it slightly and get a bit of silicone under the bottom of the tap before fixing it down. You don't want water seeping under the tap and making the worktop soft around the tap hole.
Sep 9, 2019
896
1,956
Runcorn
Autotrail Apache 632
Since Sept 2019
One of my previous existences was a job as a kitchen fitter, I always used Ronseal wet rot wood hardener around any holes Iā€™d cut into laminated or solid wood worktops, never had a problem with them ā€œblowingā€. Also used it on but n scribe joints before final assembly and glueing. Apply it with a disposable brush! Interestingly we have a sink/bathroom cabinet at home in our wet room, I used a series of cotton buds to apply it to the edges of the cabinet two years ago and the cabinet and drawers are as good as new.
Ingwe
Feb 22, 2016
3,674
11,268
York
Bailey 620 Approach
Gonna wait til I get the right tool from Screwfix. After all, DIY with the wrong tool can lead to poor results. šŸ˜‰šŸ™‚
Ingwe
Feb 22, 2016
3,674
11,268
York
Bailey 620 Approach
By way of update, bought the tap spanner set suggested by Claret in post #4. Worked well despite the cramped access. Have tightened both taps now. Thanks all for the help offered.
