loose OVEN ,, screws have fallen out , need to remove Oven (3 Viewers)
Jul 13, 2023
713
2,759
All over Europe now
Adria 680ST Gold
Noticed my oven is loose and most of thescrews have fallen out ,, was going to just replace but oninspection I can see that when it was installed it was off centre and some of the screws only went into veneer not the Plywood and most of the holes are now too big or non existant ....
im going to have to remover the oven and refill the good holes and fit fillets around the edge to drill new ones ,, Not a big job
But what im asking is the procedure for unhooking the oven at the back gas pipe and ignition wire ????? so i can pull it ot to get at the wood to fix .
Jul 7, 2021
1,914
6,892
dont own one yet.
Could you leave everything in place and pre drill under an angle with small diameter drill, then use longer screws and screw in under that slight angle, insert some CT1 with it and job done 🤷🏻‍♂️
350
876
c class
There should be enough play in the wiring and gas pipe to slide the oven out to A: disconnect the gas and electric, or B: having popped up the front of the oven carry out your preferred repair.
