Locked out of mhome ๐Ÿ˜ญ๐Ÿ™ˆ (15 Viewers)
Jul 31, 2019
946
8,875
Devon
Swift Bessecar 584
Since April 2019
Well management has often said, make sure you have your keys with you when you leave the MHome.
Well I carried Ralf outside to do his business when I heard the Hab door close. Sh.... T๐Ÿ˜ญ
Please there be a window open, locker not locked. NO.
Management had gone for a swim, she may have keys on her๐Ÿ™
I could see my keys hanging from a bag๐Ÿ˜ญ๐Ÿ˜ญ๐Ÿ˜ญ
Management will be back soon with appropriate words of wisdom ๐Ÿ™ˆ๐Ÿ™ˆ๐Ÿ™ˆ๐Ÿ™ˆ
The only "tool" I had was a fork๐Ÿค”๐Ÿค”๐Ÿค”
Management returned but no keys.. ahhhhhh.
Fortunately management had left the windows on the outer lock fixing but I had to be able to push the button in.
Fork and branch twig came to rescue, I could then lean in and pull out keys.
Phew......
Lesson that could be learnt, always listen to management ๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ‘๐Ÿ˜
Minxy
33,578
69,863
E Yorks
Carthago Compactline
carabiner-springycable-keys-belthook&pocket-first thing in the morning
Or fasten to the dog's collar so that when he's let out the keys go with him ... could be fun though if he decides to chase a cat! ๐Ÿ˜„
Oct 31, 2017
629
1,411
Kent
Carthago T149
Since 2016
Our Swift had a habit of the habitation door locking itself, thankfully the cab door was open the first time we found out :oops:
suavecarve
8,430
42,818
Surrey/Hants
Dethleffs Trend A
July 09
Should the hab door lock itself when it closes?
Ours did the other morning.
I disarmed the central locking alarm, went out for a back stretch walk, closed door after exit, then if door is closed 30 seconds after disarming it then locks.
Luckily wife doesn't get up early......apart from that morning when I got back
Lenny HB
56,327
166,293
On the coast in West Sussex
Our vans got stupid Central locking I hate it.
Unlock it and anything between 15 sec & 1min it auto relocks and it can't be disabled. I have to unlock the van open the hab door so the door contacts aren't made so when it relocks only the cab door locks.
I'm going to fit a switch on the hab door in line with the solinoid then I can unlock flip the switch and be confident it ain't going to relock.
Jan 19, 2014
9,897
26,285
Derbyshire
Elddis Accordo 105
since 2014
Phew......
You need a cockatiel, then there's always a window open to keep the van cooler ๐Ÿ˜
๐Ÿ˜Š๐Ÿฅฐ
Apr 26, 2015
3,367
8,058
Ottershaw
Hymer S820
First motorhome May 2021
Find the fuse and remove it, I didn't want the hab door and garage door unlocking whilst I was opening the drivers door so pulled the fuse.
Lenny HB
56,327
166,293
Can't operate the hab door lock manually well you can but it takes incredible effort against the solinoid. Could remove the soloniod but I think my switch is the easy answer.
Feb 18, 2017
4,896
9,543
Greenwich, London, UK
Hymer MLT 570
We keep the 'blade' of a key in a secret external place on the van.
It will only open one thing (not the hab door).
From there, if you know how, access can be gained to the vehicle, and there is set of keys hidden inside.
However you would have set off an alarm obtaining them, so you need to know how to disarm the alarm as well.
And even with a full set of keys you can not drive off, as the immobiliser needs to be disarmed as well.
And there is a further simple security issue which will stop the van being driven without the knowledge of how and where to unlock it.
Aug 15, 2022
177
331
Bristol, UK
Bailey Autograph
1 year and a bit
I wouldnโ€™t hide a key in the van, a thief could find it and I donโ€™t think your insurance company would settle your claim.
Aug 18, 2014
24,820
145,010
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
It should only relock if a door isn't opened?
If you open a cab door it should stay unlocked
Lenny HB
56,327
166,293
Nope has a mind of its own, even if it did it wouldn't help hardly ever use the cab door on an A Class.
Oct 31, 2017
629
1,411
Kent
Carthago T149
Since 2016
Its rather odd as our Carthago doesnt seem to relock even if we havnt opened a door after unlocking, perhaps its because ours is a C class, or perhaps it does but weve not been in a situation when we have unlocked but not opened :unsure:
