Strangely enough, I was just looking into that. It is a minimum 14 days. As it happens, yesterday was 14 days from when I paid the deposit.isnt there a compulsory cooling of period for services ordered online/?
but you informed them before that so it countsStrangely enough, I was just looking into that. It is a minimum 14 days. As it happens, yesterday was 14 days from when I paid the deposit.
A great bit of kit (apart from the finish on ours which I'm prepared to accept is a result of a poorly prepared batch) .Interesting. Paint problems aside - what do you think of the VanStar?
Thats interesting. I thought the LH pivot would be better.A great bit of kit (apart from the finish on ours which I'm prepared to accept is a result of a poorly prepared batch) .
I get asked more questions about the Vanstar than anything else on the van.
You need to specify one with a pivot on the RHS as this makes access to the right rear door possible without opening the rack all the way. Bikes are very easy to load and unload and so we use them more.
I can't deny its quite expensive - but to us worth it, especially as I didn't want to mount a rack on the door. And note that it's heavy so it will impact your payload, and all that weight is behind the rear axle. Despite it's weight however its very easy to swing open and closed. It can be completely removed when not required - but this is a 2 man job, just leaves the chassis mountings in place.
Par for the course with anything powder coated used outside of vehicles, slightest stone chip & moisture gets under the paint and it flakes off.The powder coat on ours started to bubble and peel off after about 9 months of light use.
Our van has a large store cupboard behind the RHS door, this makes access to that cupboard easy. Not relevant if you don't need access to the right hand door the most - I was forgetting that. Also, we mostly use it abroad, so ours opens to the kerb side over there. If you are predominantly UK based then the other way might be safer I suppose.Thats interesting. I thought the LH pivot would be better.
Re weight/payload - we are replating our AS Symbol from 3300kg to 3500kg. I have just added air assist suspension which means the rear axle payload will be higher. I think that should take care of the weight issue
