- Nov 22, 2018
- 2,023
- 21,646
- Rimor Europeo 87
- Seven years plus three tugging
Going lithium in June.
Which is better. One 200a or two x 100a?
This might not be very helpful at the moment you can make a brilliant toad in the hole in a romoska and as your going lithium it’s a life changerId love to, but the boys have mega autism (non-verbal and semi-verbal) and the younger (the semi verbal one) only eats eight things, four of which you can't get outside UK!!! Has anyone ever seen Yorkshire puds in Carrefour or SuperU?!!!
Our Thetford fridge is compressor only and draws 3.6A when on the running duty cycle. I have extrapolated that it will run 10 days on our 230Ah Lithium battery with no other consumers other than a Battery Master.Thanks everyone. How long will your setups power a fridge? Im thinking of the 8 hours+ time on the Portsmouth St Malo ferry.
I've got an Alpicool 25l 12v cooler/freezer which I use when travelling solo, brilliant. Hardly makes a dent in the current AGM battery overnight. The only downside is it can only be a fridge or a freezer, not both at the same time but not a problem for me. No need to use the fridge on gas when staying on aires without hookupUnless this is a one off... how about investing in a 12v freezer box?
I have one I used to use for Kerry's [RIP] frozen raw food blocks.
Works a treat
Well I contacted 3 battery manufacturers they all if you can get one large it’s better than two smaller. Reason less complicated
Roamer can handle 250amps well my single 460 canThe only reason I would consider two / one battery is if a single battery couldn't handle the load placed on it, which will be down to BMS and manufacturing design.
Alan when I say less complicated I mean 1 BMS less wires if you have more than one your BMS dosnt talk to the other so after 12 months or so you probably need to level them up ? But there’s nothing wrong with more than one. It’s like built in heaters better off without if you can less to go wrong. That’s what I was told with the manufacturersIt’s not complicated Mike at all, I can see both my 280ah Drift batteries either on the Fogstar app, the Xiaoxaing app and the Victron shunt
and if 1 goes t!ts up i’ve always got the other to fall back on
Likewise the 230AH Fogstar does 250AH continuous discharge.Roamer can handle 250amps well my single 460 can
Got one already! A Dellonda or something. Brilliant kit, far better than the van fridge. Trouble, is we therefore have two fridge freezers we need to keep poweredUnless this is a one off... how about investing in a 12v freezer box?
Works a treat
Some 12V fridge elements are not controlled by a thermostat, they are on all the time. Mains 230V elements will be controlled by a thermostat. The fridge temperature control turns up/down the set point of the thermostat. The thermostat is the simple on/off type, so if it switches the element off for 50% of the time it will use only 50% of the power.2. That amperage reduces if i turn the fridge down from 5 to 2?
It’s like built in heaters better off without if you can less to go wrong. That’s what I was told with the manufacturers![]()
1. The amperage will not be continuous especially if a compressor fridge. The actual current drawn does not vary by much. It is the on-off duty cycle that varies.This has been extraordinarily helpful. Can i then confirm my understanding?
1. So i find out the amperage draw on the van fridge\freezer, (230v, 12v, and gas) and the draw of our coolor box (12v and 230v) and i get my total amperage need?
3. 12v is less efficient, but the 230v inverter runs the battery down quicker.
Air fryer Same thing only on steroids you also end up with a tan golden brown! Oh! and crispy ! Still hope for though you Jim , it seems you’ve stumbled across the the doorNo idea what an Air Fryer is, I'm guessing it's a kitchen thingy. Not my department.![]()
