Lithium charging voltage at start
On my android pad I tried to use the Remote VEconfigure button to download the Multiplus settings, but although it went through the process the file didnt turn up!
It did turn up, but you need the VE config tools to open it. And as far as I know, VE config is windows only.
Sure - but the file could be emailed to someone so the settings can be shown - just to eliminate the possibility.....
Just tried it again on my android phone - like you say it did turn up, but file extension was a .TXT! Changed that and it worked!
Just while you wait for you friends help - in the settings on VRM/Cerbo you will see a DVCC menu item -If it is turned on there is a setting to limit battery charge settings, so might be worth a check. DVCC may be turned off though.
You also mentioned "Pro" so I guessed at Fogstar Drift Pro, which can be connected to the Cerbo via the can ports, at which point the battery should be managing the charge, then I guess the limit would be in the Multiplus settings, which you will know tomorrow.
Do let us know - have been wondering about using the drift pro......
