I'm about to update our batteries in our Carthago to Lithium so will need a B 2 B, new Mppt controller etc
At this time after looking at lots of things online including Fogstar etc
I'm probably going to put a minimum 300Ah-560Ah battery pack together myself with a 200a BMS probably with Eve cells from Fagstar as they seem as competitive as any.
Also another option is a Chinese company called Blackcell who have CATL cells which they say are Grade A and delivery in about 5 days.
Been looking into B 2 Bs and someone has said that the Sterling 1260 B2B doesn't actually charge at 60A. His would only get to 48A and it seemed when the unit got hot it went down to 22a.
Has anyone any experience with this?
Is this common to all charges?
I do quite like the look of the Votronic 50a B2B.
At the moment the CBE has a 70A split charge relay of which I'm either going to disconnect at the CBE or use a normally closed relay like my mate Steve Greenhalgh, which is working fine.
Also if anyone has any other recommendations on Lithium battery builds, maximum safe size of B2B charges without altering existing wiring etc.
Also if anyone has used Blackcell or CATL cells that would be much appreciated.
