Lightweight Sewing Machines -Any Good?
@Puddleduck i only use schmetz needles but have to buy them online as they’re not easy to obtain in the wilds of south west wales !
Schmetz or Superior, both are good brands. I've used the titanium needles and they do stay sharp longer but I am not convinced they are worth the extra money. I like topstitch needles for both piecing and quilting.
just spent three hrs servicing this thing getting all the fluff out the works it was minging worked out how to thread it working very smooth but it keeps braking the thread
bill
Bill you probably need a better quality thread as cheap thread does tend to break easily. If it's not the thread then it will be the tension that needs altering.
Denise
I’m thinking about how /whether I’m going to take my second best machine (Janome TXL607) with me on our extended travels next year. I’d really like to as I enjoy sewing but the weight, plus all the bits and pieces such as scissors, rulers etc may be prohibitive.
Plus how much of your fabric stash would you want to take with you? Think I have about 6 of those underbed storage boxes of fabric waiting to be used:xblush:
So I may have to make do with taking knitting, crochet and cross stitch projects instead which are considerably lighter.
I also knit, crochet (badly), occasionally do macrame and make rugs from old quilt covers. Mabe I should be looking for a double decker busxroll:
I do think you’ll be better off with a full sized machine if you’ve got the room / payload for it.
Yes I agree, will have to find space & weight for a full size one.
Would that explain your forum name? :xgrin:
I did wonder if anyone would notice, I read through the joining form 3 times before hitting enter and it did not compute. I only saw it after I had made several posts. Probably should have ditched the 4, remaining number would then be closer to current mental age:xblink:
Denise
Or you might have the wrong size or type of needle.
Are you using the same thread top and bottom? Easier if you do.
Old thread will also dry out and snap.
Is the bobbin in correctly?
When I have problems this is what I do:
Clean and oil
Change the needle
Change the bobbin for a newly wound one.
Unthread and rethread top and bottom
This generally sort s out any issues.
That is a very good point well made. A motor home isn’t the easiest of places to lay out a quilt ready to stitch!
Yeah, I had trouble typing it :oops: I do have a habit of getting letters and numbers confused.
On this forum you do not have to answer to any one on spelling or grammar
It is written in stone rule 1 best rule on the inter net any one that cant make out what your trying to say on her obviously has a problem so don't worry abut it
bill
Depending how much time sewing may decide if you need a hook up or an inverter which would then affect your weight with extra batteries and solar panels so not just weight of machine
