- Jul 5, 2013
- 11,984
- 14,228
- A class
- Since 2013
I have 2 x 120Ah lithiums supplied by KS Energy, which I fitted in the spring of this year. When we are not using the motorhome this winter my plan is to isolate my Lithium leisure batteries when not in use, but still trickle charge the lead acid cab battery via solar and/or EHU so that the Growler alarm and non-starter still works and the engine electronics still work. I envisage the longest period the motorhome will not be in use will be 3 months.
Is that sensible and what state of charge should I leave them at ?
My set up at the moment is
- An EBL29 that acts as a trickle charger to the cab battery and 12v distribution board. It does not charge my Lithiums because I have removed the 20A fuse.
- A Votronic 30A B2B
- 250W of solar panels via a Votronic MMP350 solar charger that charges the Lithiums and trickle charges the cab battery via the EBL
- A Victron IP22 charger for the Lithiums, which can easily be switched off.
