Just driven the length of New Zealand in our LHD . No problemWere hoping on getting a classic Hymer and as they seem to be readily available in either, were only going to be in the 8-13k market, will that make a difference ?
Would think that is a "driver feature" as much as where the steering wheel is.Now here's a thought, do lhd m/h's in the UK suffer less mirror breakages due to better road positioning?
LHD is easy here and easier across the channel, take a look on Link Removed you might find a better deal with your budget.
Easy I have never bought anywhere else in my case always been new vans. If you use the forums search facility you will find dozens of threads on importing.Wow 3 available, I don't know if I'm brave enough to buy abroad, is it difficult to organise please?
That is very true, I've looked at mirrors to rectify this lack of direct sight at oblique junctions but can't find one that's compatible with my mirror guard thingies.I've had both LHD and RHD motorhomes. The difference between them, in my opinion, is dwarfed by the difference between driving a car and a motorhome.
Either way, either here or abroad, you quickly get used to it. The major problems - eg at oblique junctions - are equal: LHD will have problems on a sharp left hand junction, and vice versa regardless of which side of the road you're using.
What LHD or RHD ?Just an observation from when I'm out on my bike, I do notice a few mh's with a large gap to the kerb or hedge.
Lol that's put me off slightly, seeing as i'm going for an older van, there's no guarantee it will pass it's MOT over here and then I might get stuck with something huge needing doing, Thank you for the link though I might just stick to the UK
Thank you had no idea what that meant xWhat LHD or RHD ?
If it has passed a TÜV then a brit mot won't be a problem.
German TUV test is far stricter than our MOT so if it passes a TUV should fly through an MOT.Lol that's put me off slightly, seeing as i'm going for an older van, there's no guarantee it will pass it's MOT over here and then I might get stuck with something huge needing doing, Thank you for the link though I might just stick to the UK
Just make a holeThat is very true, I've looked at mirrors to rectify this lack of direct sight at oblique junctions but can't find one that's compatible with my mirror guard thingies.
Summed up perfectly, the only thing I would add is I felt it was better to "be sat on the wrong side" over here where I knew the roads, and on the correct side "over there"
Andrew
Just make a hole
I have an RHD van, but most of its mileage has been done on the contintent [ should that be kilometreage ] and the only issue has been joining motorways from sliproads. Having to rely on a non-driver passenger to tell you it's safe to proceed can be hair-raising. There must be a mirror extension that can solve this.That is very true, I've looked at mirrors to rectify this lack of direct sight at oblique junctions but can't find one that's compatible with my mirror guard thingies.
You can get blind spot mirrors that can be attached to the existing door mirror, the ones that clamp on top are the best, and you can angle them to 'see' whatever you need so should be able to set them up for 99% of the time you need a view when coming on from a slip road.I have an RHD van, but most of its mileage has been done on the contintent [ should that be kilometreage ] and the only issue has been joining motorways from sliproads. Having to rely on a non-driver passenger to tell you it's safe to proceed can be hair-raising. There must be a mirror extension that can solve this.
Reckon I'd better get one before the next trip over the water -- could add a few years to my lifeYou can get blind spot mirrors that can be attached to the existing door mirror, the ones that clamp on top are the best, and you can angle them to 'see' whatever you need so should be able to set them up for 99% of the time you need a view when coming on from a slip road.
Why not stick some of these on ... they'll scare the bejeezus out of those coming towards you especially on a black background!Reckon I'd better get one before the next trip over the water -- could add a few years to my life
