• Well done, you found us. THIS IS THE NEW SERVER
Levelling up (1 Viewer)
Agzy
89
217
Wirral
Bessacar E410
As a newbie to solo motor homing and used to levelling a caravan with either lock and level or yellow ramps and mover, just wandering how fellow solo travellers manage to use ramps without anyone to guide when levelling a MH please?
mikebeaches
5,416
8,657
Bristol
Rapido V68 Van Conversion
You get used to it!
If you get the Milenco stepped ones, it is easier.
As Janine says, with Milenco levelers you can feel and count each step as you drive up.
54,091
152,664
You could fit E & P Jack's then you just press a button and the van self levels. Not cheap about £5½k lots of Funsters have them and rave over them.
We have air suspension that gives us a fairly good leveling but nowhere near as good as E & P, we had it fitted to improve the ride, it's a lot more expensive than the Jack's.
Dec 16, 2017
1,231
2,525
Almuñécar, Spain
Low Profile - Globebus T7
Our ramps are just plain flat triangles (ie no pockets or steps) but my dead easy system is this (Ducato based so 95 times out of a 100 we need to go up at the front) :
1 Place the ramp in front / behind the wheel and gently kick it so it's just under the tyre.
2 with your shoe / a stick draw a line at right angles on the ground marking the end
3 draw a second line marking the wheel centre.
4 the distance between these 2 lines is the max distance to drive up onto the ramp
5 of yiu can't see these lines by looking out the window or under the door then draw 2 more the same distance apart under the drivers door where you can see them
6 drive up that distance. When yiu stop and put the brake on you will drop back down a tad. As long as the centre of the wheel is not "over the edge" it should be fine.
7 check your spirit level, drop back down a bit if needed.
Works for us but, as always YMMV...
Agzy
Agzy
89
217
Wirral
Bessacar E410
Way way out of my league and bank account !!
Gellyneck
9,482
19,009
More than toes wet now!
You could fit a "stop" to the high end of your ramps. You just need to make sure it fits under the bodywork.
MisterB
6,068
13,598
Adria 670 SLT
some fridges wont work on gas if not level (or close to it!)
stepped ramps work best for me, and as has been pointed out, just make sure they are straight and in line with the MH and slowly drive onto them or up them after having 'kicked' them under the tyres first to hold them
DJT
Jun 20, 2019
456
32,055
Cumbria
Now Sold
The only thing that works for me and MOH is LEVEL hence E&P jacks!!
Wonder where the old saying (level headed) comes from!
DJT
DJT
Jun 20, 2019
456
32,055
Cumbria
Now Sold
DJT
Dec 16, 2017
1,231
2,525
Almuñécar, Spain
Able to see pros and cons without applying bias. Mentally balanced. Having an even temprement. Able to see the good and bad in a situation and make unbiased decision based on facts instead of emotion.
Reactions: DJT
11,963
16,583
This discussion illustrates that accessory manufacturers don't improve their designs. Surely the answer is ramps that have an up and a down slope - like existing ramps back to back with a hinge in the middle. If there was a short flat on top the highest setting would be easy to find too. They'd take up more room and payload but think of the convenience.................
ABZSteve
Banned
Jan 8, 2014
1,524
1,658
Aberdeen
2018, Apache 634 150 Auto
I level, I don’t, I level, I don’t. Please myself what I do depending on the slope or how I feel, not how others think I should feel. Always do it by myself though if I do level, but you can ask for help if required(y)
