Lenny it took me a week to enjoy booze again don’t be despondent![]()
PS; i didnt say i didnt enjoy it it!! it just upset the stomach...
Not really she has never driven this one and the roads are so busy here.Is Mi game to drive the MH Lenny? If so it would mean you could move somewhere else and get some charge back in the batteries.
Yes I know, are you trying to teach me to suck eggs (.... or tablets!)Not really she has never driven this one and the roads are so busy here.
Batteries will last a while yet I've 3 Gels and they can go down to 20% without a problem.
Good news Lenny!
I agree with what you said about the treatment EXCEPT the sore backside - that had nothing to do with the treatment![]()
Any Victron BMV experts out there?
I'm normally pretty clued up on this sort of stuff but brain has left the house this week.
Had low battery warning this morning batteries at 11.7v which under load is OK.
Battery state of charge showing 45%.
With every thing turned off which is near as no load I can get its 11.85v which would indicate a flat battery but off load voltages are only a guide .
Batteries are 3 x 78a/h Gels (234a/h)BMV set to 230a/h.
Consummed a/h showing as 180a/h which would be 80% but I'm not sure if this takes into account charge input.
Ever since I've had a BMV I've never been convinced the state of charge to voltage is correct.
Something I really don't want to do is run the engine stationary but may have too. My 300 Watts is producing less than an amp today.
That's what I assumed brain just not in gear at the moment.Yes Lenny the charged ammount does take into account input, otherwise there would be no point monitoring the state of charge. However it would only measure this if the shunt was correctly connected and that no other inputs/outputs were made between the shunt and the battery.
Really just laying out my thoughts I understand Motorhome battery use pretty well.@LennyYou might be better starting a new thread with a battery title. You may get more replies. Good luck
I’m not a battery expert Lenny but your batteries are a fair few years old now and may be struggling to hold their charge, especially if you are drawing high currents via an inverterThat's what I assumed brain just not in gear at the moment.
But batty voltage does not tie up with state of charge and I know its all set up correctly.
Two of them are 4 years old and one 3 years old generally considered youngsters for Gels.I’m not a battery expert Lenny but your batteries are a fair few years old now and may be struggling to hold their charge, especially if you are drawing high currents via an inverter
Does your van control panel show voltage?Two of them are 4 years old and one 3 years old generally considered youngsters for Gels.
Inverter not very often used last time was on the Chunnel to make a brew on the way over.
We have been totally off grid now for 12 days with very little sun. So they are doing quite well. Just the readings don't coordinate.
Nope only approx but the BMV is accurate on voltage still getting meter out will gine me something to do.Does your van control panel show voltage?
The starter battery has a CBE solar relay connected to it so on the few days we have had some sun it will have got a bit of a charge.Hope this isn't reading your starter battery as well else you won't be able to start the van shortly.
Should have come to Spain,,sunshine and I bet the hospital food is betterTwo of them are 4 years old and one 3 years old generally considered youngsters for Gels.
Blame the boss for that.Should have come to Spain,,sunshine and I bet the hospital food is betterBUSBY.
There are a couple close by but I'm not really up to driving yet.Where are you at the moment. I've been finding Free Stelplatz with very cheap power. 2€ per 24 hours at one two-day ago. Last night - 1€ per six hours. Could help until the sun makes an appearance.
Because it buggers modern diesel engines, as they never get up to operating temp just on tickover. Also buggers Cat & DPF.Just one point I am not clear on , is why can't you run the engine?
The 180 does include the solar its has in over the last week.Taking 180ah out of 230ah sounds about right with your estimation of 80% discharge, and voltage is about right to
I just resorted to running the engine for ½ hr consumed a/h now showing 164.If the -180 you read on bmv, that’s what did came out of the batteries at that time. Solar has been eaten on the other side of the shunt.
Me tooGlad your on the mend Lenny,,,crickey reading some of these posts I am dreading old age...BUSBY.
Pffft he was never king ....a mere knave at best ....ive seen his spendingHope all goes well for your recovery Lenny. It could be worse just think of the pain you would be in, if you where having to pay 20 euros a night to stop where you are , you would also be in danger of losing your title as King of the FLT brigade.
James
