leisure battery (1 Viewer)
Rabc
25
19
Birmingham
van conversion
7 years
i think my leisure battery is coming to the end of its life it charges on run to full power but after a couple of days it seems to lose some of its charge,ive tried a smart charger and it showed 60% but left it on to charge fully but after a week it went down again the led lights worked but the fluorescents were dim,is it time tonite the bullet and replace it.
cheers for any suggestions.
Rabc
Rabc
25
19
Birmingham
van conversion
7 years
nothing i can find the 12 volt is turned off at the panel.
May 31, 2015
11,783
44,929
Cornwall
Ducato PVC
Getting Better
Are you saying that you charge the batteries then use the power for a few days then charge again..? ie: lights pumps tv..? Is it getting a regular charge via solar or EHU..?
Rabc
Rabc
25
19
Birmingham
van conversion
7 years
It charged on a long run and lasted for a while the I used a smart charger and it lasted for a week
May 31, 2015
11,783
44,929
Cornwall
Ducato PVC
Getting Better
You mean the van is just standing doing nothing, not used at all...?
sorry if it’s me... just trying to get the facts so you get the right answers...👍🏼
Rabc
Rabc
25
19
Birmingham
van conversion
7 years
At the moment but 2 weeks ago I done 340 miles on a trip and it charged fine
May 31, 2015
11,783
44,929
Cornwall
Ducato PVC
Getting Better
Well in that case it looks like it’s coming to an end... what battery is it and how old..?
Rabc
Rabc
25
19
Birmingham
van conversion
7 years
it’s a bosch 80ah i don’t know how old i’ve only had the van for 12 months it’s 06 autosleepers duetto
May 31, 2015
11,783
44,929
Cornwall
Ducato PVC
Getting Better
That doesn’t sound like a leisure battery to me....?
Rabc
Rabc
25
19
Birmingham
van conversion
7 years
Why is that there’s 2 under. The seat and there’s a label on it
May 31, 2015
11,783
44,929
Cornwall
Ducato PVC
Getting Better
Invest in a good Leisure battery and maybe a solar panel to keep it topped up, I’d also get he fluorescent lights and others change to LED’s..
Rabc
Rabc
25
19
Birmingham
van conversion
7 years
ive got leds all round apart from fluorescents on ceiling.when you said it didn’t seem like a leisure battery what did you mean?
Rabc
Rabc
25
19
Birmingham
van conversion
7 years
could be there’s 2 batteries under the seat the other ones a Varta but when I put a smart charger on it it was full and the Bosch was only 40 per cent
43,396
49,921
Don't understand that.
Both batteries should be physically linked together so whatever the voltage and percentage on one will be identical on the other.... Unless you disconnected and charged them seperately.
Gellyneck
9,334
18,565
Scotland
More than toes wet now!
Guess the first thing you need to do is determine which battery is which if you believe one to be a leisure and the other a vehicle battery.
Rabc
Rabc
25
19
Birmingham
van conversion
7 years
The only way to do that is disconnect the battery is that right?
May 31, 2015
11,783
44,929
Cornwall
Ducato PVC
Getting Better
I’m no expert and getting all the info and the full picture is not forthcoming... we’ll get there in the end and sort it...👍🏼
Feb 9, 2008
8,959
18,712
Corby, Northants
Coach Built
If I have read this correctly, the O.P. has a Varta starter battery and two Bosh Leisure batteries under the seats ? Moving on, The leisure batteries will have a reduced life span if allowed to discharge more than 50 % of their total capacity and the more this happens the quicker the batteries will loose their capacity and die. It's hard to tell from the information supplied how they are being used but I suspect they are allowed to be significantly discharged before being charged up again. If this is so they could be on there last legs. I would advise to give them a full charge on hook up for at least 36 hours and then see how they perform and take it from there.
Feb 9, 2008
8,959
18,712
Corby, Northants
Coach Built
Yes! I have it now, 2 Bosh leisure batteries , probably the 90 A.H LFD 90. Give them a full charge as stated above and take it from there. How long have you had them.
Rabc
Rabc
25
19
Birmingham
van conversion
7 years
No there is only one leisure battery side by side under the seat I surmised that the leisure battery was the Bosch because it had a lable on and when I attached the smart charger it was on 60 percent.
mikebeaches
5,407
8,638
Bristol
Rapido V68 Van Conversion
Since 2009
If the engine is still starting OK, it's almost certainly the habitation battery that's come to the end of it's life.
I've just had to get ours replaced. Details on this link. Unfortunately, I'm not really strong enough to be handling large 25kg batteries and manoeuvring into the required space, so needed to find somebody to do it. There's nothing difficult, just the weight.
In case it's of help, I found Halfords sell a selection, but they wouldn't install it.
43,396
49,921
